James Boo
| PIC 18F4550 clock frequency problems |
Posted: Thu Nov 09, 2006 2:34 pm |
I am working with an 18F4550. For the #FUSES, I have selected
#FUSES HS, NOPROTECT, NOLVP, NOBROWNOUT, NOWDT, NOMCLR, NOPUT
With this setting, the PIC is completely unresponsive--it just doesn't work. When I change the #fuses settings to:
#FUSES HS, INTRC, NOPROTECT, NOLVP, NOBROWNOUT, NOWDT, NOMCLR, NOPUT
The PIC works, but the frequency is way too slow for what I need it to do. How do I get it to work at 8MHz frequency? |
Posted: Thu Nov 09, 2006 3:25 pm |
Here is a test program for the 18F4550 that runs off the internal
oscillator at 8 MHz. I tested this with PCH vs. 3.249 on a PicDem2-Plus
board.
#include <18F4550.h>
#fuses INTRC_IO, NOWDT, PUT ,BROWNOUT, NOLVP
#use delay(clock=8000000)
output_high(PIN_B0);
output_low(PIN_B0);
Posted: Thu Nov 09, 2006 3:31 pm |
Without knowing what type of oscillator you want to use, it'll be a guess. HS, _requires_ an external crystal. If you do not have one, get rid of it. INTRC, implies operation with the internal oscillator.
#FUSES INTRC, NOPROTECT, NOLVP, NOBROWNOUT, NOWDT, NOMCLR, NOPUT
Should normally give you 8MHz. However on some compilers, you may need to have the line:
setup_oscillator(OSC_8MHZ);
Near the start of the main (the compiler should generate this internally, automatically if the correct 'delay' statement is present, but it is safer to include it yourself).
