can we overload a compiler function?
asmallri
PostPosted: Mon Oct 23, 2006 11:52 pm     Reply with quote
I am using a PIC18F8722 with PCWH 3.249
This PIC has a problem with the SPI (lots of problems) and I need to implement a work around as per the errata. My code base supports multiple different PIC families so I need a mechanism to address just the 8722 and variants.
What I want to do is be able to substitute the CCS spi_read() function with my own. I do not want to use a different function name. The compiler seems happy to accept it but will not use it. Can internal functions be overloaded in this version?
Failing that, can I disable the internal function?
Regards, Andrew
PostPosted: Tue Oct 24, 2006 4:17 am     Reply with quote
#define, can be used, since the macro expansion, takes place before the main compiler pass. So:
#define spi_read(x) my_spi_func(x)
Will replace all internal calls to 'spi_read', with calls to your 'my_spi_func' function.
