andreluizeng
| problem with pointer to an array |
Posted: Fri Oct 20, 2006 8:15 am |
hi people,
does not ccs suport it ?
im trying to pass buffer's addres to a routine... but i gave some errors.
char Buffer[10];
routine (char **Buffer); --> routine (&Buffer);
doesnt work.
regards. _________________ Andre |
Neckruin
Posted: Fri Oct 20, 2006 9:16 am |
If you wish to pass the buffer address you have to do like this:
| Code: | char Buffer[10]
void Function(char *buf) {...}
Function(Buffer); |
It's like ANSI C... or very similar
Regards,
Juanma |
andreluizeng
Posted: Fri Oct 20, 2006 9:51 am |
sorry.. but it isnt my purpose..
i want to change values of buf by reference..
like this:
change (&buf);
change (char ** buf)
char i;
for (i = 0; i < 8; i++)
(* buf)[i] = i;
return;
got it ?
regards _________________ Andre |
Neckruin
Posted: Fri Oct 20, 2006 10:16 am |
If you wish to change the value of, for example, Buffer[i], I mean, the content of that "line" of the buffer, you can do it like this:
void Function(char *Buffer)
int i = 0;
for(i=0; i<LIMIT; i++)
Buffer[i] = value;
Then, to call that function in order to modify tha content of your Buffer you must do like this:
| Code: | char MyBuffer[SIZE];
Function(MyBuffer);
This should work, but anyway I haven't tried out it right now. I say it should work because the name of the char array is a pointer itself.
Juanma |
andreluizeng
Posted: Fri Oct 20, 2006 10:25 am |
Juanma,
ill try..
but its quite diferente for the ANSI C, because you need to pass and address to change its value... and no pass the value to change it...
but ill try.
thanks _________________ Andre |
asmallri
Joined: 12 Aug 2004 Posts: 1676 Location: Perth, Australia
Posted: Fri Oct 20, 2006 10:34 am |
long hand works...
| Code: | typedef char* pchar;
pchar *buf; |
_________________ Regards, Andrew
jspencer
Joined: 22 Dec 2003 Posts: 57 Location: Boise, ID USA
Posted: Fri Oct 20, 2006 11:09 am |
int16 nal;
read_eeprom_block(&nal, 2, NEXT_ADDRESS_LOCATION);
void read_eeprom_block(int8 *mem_address, int8 num_bytes_2_read, int16 address_location) {
int8 i;
for (i=0;i<num_bytes_2_read;i++)
*(mem_address + i) = read_ext_eeprom(address_location + i);
Is this what you were looking for? It is not an array, but a int16. Should work the same for a buffer. |
andreluizeng
Posted: Fri Oct 20, 2006 11:34 am |
jspencer,
is almost it =)
but you take the point.. when you want to set a value for a variable by reference, you have to pass its address...
so if you have an int8 variable, u just pass a pointer to the function...
like you did.
but when you have a vector of int8 you have to pass a pointer to pointer.. or point to array...
insted you do function (int8 *var)
you need to do function (int8 **var)
got it ?
and ccs doesnt support that !!
thanks for your help. _________________ Andre |
andreluizeng
Posted: Fri Oct 20, 2006 11:35 am |
asmallri
hmmmm, i wont thought about your sugestion... ill gonna try. _________________ Andre |
andreluizeng
Posted: Fri Oct 20, 2006 11:37 am |
asmallri
it didnt work at all =( _________________ Andre |
JPA Guest
Posted: Sun Oct 22, 2006 9:27 am |
I have read all the posts and I still do not understand what you want to do.
If you declare
char Buffer[10];
then: Buffer is a char * and points to the first element of the array.
Buffer[i] is completely equivalent to *(Buffer+i)
In your 1st post, as you have declared
char Buffer[10];
the expression &Buffer has no meaning.
If you want to modify the contents of Buffer in a function, you just have to call the function with Buffer as argument: the_funtion(Buffer).
Inside that function, if you write Buffer[i] = 10, you will modify the original Buffer.
If you need more explanation, I advise you to read the "Bible" of C programmers, the K&R book.
JPA |
andreluizeng
Posted: Sun Oct 22, 2006 10:21 am |
Dude, you dont understand.
you can use a pointer to an array in C (im not a newbie in C)
if you want to pass the buffer itself you need a pointer to it..
as you shown above, you are passing a pointer to a position of a vector.
look at that..
i want to create a general function for all size of buffers like that:
void ZeroValue (char **Buffer, int8 Lenght)
int8 i;
for (i = 0; i < Length; i++)
(* Buffer)[i] = '0';
return;
and you call this function like that:
void main ()
int8 i;
char Buffer[20];
for (i = 0; i < 20; i++) Buffer[i] = '1'; // here we fill the buffer with '1'
for (i = 0; i < 20; i++) printf ("%c", Buffer[i]); // send the values to rs232, and you will receive all values '1'
ZeroValue (&Buffer, 20); // changing values
for (i = 0; i < 20; i++) printf ("%c", Buffer[i]); // send the values to rs232, and you will receive all values '0'
return;
in this way i dont need to pass just a single position of the buffer, i just pass the complete buffer.
got it ?
just try to do it in a C compiler for PC. YouŽll see that works
Neutone
Posted: Sun Oct 22, 2006 10:50 am |
You can't pass an array on an embeded chip. You must pass a pointer to the memory location the array already exist at. When you add the length to the argument you can modify memory location from the pointer for length locations.
There are some things that can not be done with an embeded chip. The C language is supposed to adapt to the platform you compile for. For example variable types such as a long are not the same for each platform. |
Posted: Sun Oct 22, 2006 4:57 pm |
I can't get your test program to compile under MSVC++ 6.0 (as a .cpp)
or under MSVC vs. 1.52 (as a .c program).
I changed all the 'int8' declarations to be 'int', and I fixed the mis-spelling
on 'Length'. I get the following output with MSVC vs. 1.52:
| Quote: |
Initializing...
Compiling...
c:\msvc\projects\test\test.c
c:\msvc\projects\test\test.c(35) : warning C4047: 'argument' : different levels of indirection
c:\msvc\projects\test\test.c(35) : warning C4024: 'ZeroValue' : different types for formal and actual parameter 1
TEST.C - 0 error(s), 2 warning(s)
Both of those errors refer to this line:
| Code: | ZeroValue (&Buffer, 20); // changing values
The reason that I tested it under MSVC is because it's implicit in your post
that the code will work under "real C", but fails in CCS. Can you post
a revised test program that will compile in MSVC ? |
andreluizeng
Posted: Sun Oct 22, 2006 6:50 pm |
Hi people..
PCM, here is the code.. you can compile in any compiler.
#include <stdio.h>
#include <stdlib.h>
void InitBuf (char **Buf, int length, char Value)
int i;
for (i = 0; i < length; i++)
(* Buf)[i] = Value;
return;
int main ()
char *Buf;
int i;
Buf = (char *) malloc (sizeof (char) * 10);
InitBuf (&Buf, 10, 'A');
printf ("First Values: ");
for (i = 0; i < 10; i++)
printf ("%c ", Buf[i]);
InitBuf (&Buf, 10, 'B');
printf ("\nSecond Values: ");
return 0;
i change a static buffer to a dynamic buffer, but ive tried it in ccs and didnt work either....
