forwardti Guest
[help] "fprintf" can not display normally |
Posted: Thu Oct 19, 2006 11:36 am |
now I have a GPS receiver called GPS 35LVS and I want to use it on the platform of 16F877A. The compiling environment is CCS and ICD u40. Now I want to receive the data from the GPS and echo them to Debugger monitor via ICD U40, and there are some problem with the fprintf built-in function. Because I will use RS232 for GPS and RS232 for Debugger, I have to use fprintf fucntion to display the data on the monitor, however it can not display normally, just like something about Chinese characters. And, when I just use RS232 for debugger, the printf fucntion can perform normally. I do not know why.. A lot of thanks in advance for your kind ...
by the way, my notebook Operating System is Windows XP Chinese Edition
here is the code.
Code: | #include<16f877A.h>
#device ICD=TRUE
#use delay(clock=8000000)
#use RS232(baud=4800, parity=N, xmit=PIN_C6, rcv=PIN_C7, stream=GPS)
#use RS232(baud=9600, xmit=pin_B3, rcv=pin_B3, stream=DEBUG)
VOID main ()
INT i;
CHAR GPS_packet[70];
CHAR c;
DO
i = 0;
FOR (i = 0; i <= 70; i++)
c = fgetc(GPS);
GPS_packet[i] = c;
FOR (i = 17; i <= 40; i++)
fprintf(DEBUG,"%C",GPS_packet[i]);// here is where the problem exsit.
}WHILE(kbhit());
Posted: Thu Oct 19, 2006 12:58 pm |
The CCS manual doesn't say the keyword is 'DEBUG'.
It says it is 'DEBUGGER'. |
Posted: Thu Oct 19, 2006 4:02 pm |
I find it in the CCS help document, in the Built-in Function->RS232 I/O->GETC, and there is an example on the bottom.
printf("Continue (Y,N)?");
do {
answer=getch();
}while(answer!='Y' && answer!='N');
#use rs232(baud=9600,xmit=pin_c6,
rcv=pin_c7,stream=HOSTPC)
#use rs232(baud=1200,xmit=pin_b1,
rcv=pin_b0,stream=GPS)
#use rs232(baud=9600,xmit=pin_b3,
stream=DEBUG)
while(TRUE) {
c=fgetc(GPS);
fputc(c,HOSTPC);
if(c==13)
fprintf(DEBUG,"Got a CR\r\n");
Posted: Thu Oct 19, 2006 4:27 pm |
I don't have the CCS ICD-U40, so I can't test it for you.
All I can do is to read the manual. The last manual for vs. 3.249
of the compiler, says to do it this way:
Quote: |
Debugger - Monitor
The monitor window shows data from the target and allows entry
of data to be sent to the target. This is done on the target like this:
#use RS232(DEBUGGER)
... printf(“Test to run? “);
test=getc();
For the PIC16 ICD the B3 pin is used on the target to implement this
capability. The normal ICD cable is already set up correctly for this.
The current manual for vs. 4.xxx also says to use the keyword DEBUGGER.
DEBUGGER Indicates this stream is used to send/receive data
though a CCS ICD unit. The default pin used in
B3, use XMIT= and RCV= to change the pin used.
Both should be the same pin.
My suggestion is, if you are having problems, then follow the manual
exactly.
I can't help you any more on this topic. Someone else who has the
ICD-U40 will have to help. |
forwardti Guest
Posted: Fri Oct 20, 2006 1:57 am |
okey! Thank you a lot.
I wil try that.
Actually, I thought only when I use "#use RS232(baud=9600, xmit=PIN_B3, rcv=PIN_B3, stream=DEBUG)", could I use the stream DEBUG for the monitor under the condition of two RS232.
so, I'll try that, Thank you! |
