jweller
| 12f683 interrupts |
Posted: Mon Oct 16, 2006 3:52 pm |
I've got a couple interrupts up and (mostly) working but right now they both go to the same ISR. Is there anything built in to check which pin generated the interupt, like a flag set in a register, or am I on my own for that. One int is a pushbutton, so I can just debounce it and check the state of the pin, but the other is rs232 data coming in, so there is no telling what state it might be in. If I miss the debounce, I'll handle the int wrong.
edit: compiler version 3.249 |
Posted: Mon Oct 16, 2006 6:14 pm |
You could use the INT_EXT interrupt (pin GP2) as the Rx pin for the
software UART. Then another GPIO pin with the Interrupt-on-Change
interrupt, to handle the push-button.
Here is a rough outline of how to do it. I haven't tested this code in
hardware. I just compiled it, and it compiles OK. I don't guarantee
that this works. I don't have time to test it in hardware, right at the
moment. But it should give you a start. I compiled it with vs. 3.249.
#include <12F683.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, PUT, BROWNOUT
#use delay(clock = 4000000)
#use rs232(baud=1200, xmit=PIN_A4, rcv=PIN_A5)
#int_ra
void ioc_isr(void)
int8 c;
// Put code in here to handle the interrupt
// Read Port A to clear 'change' condition
// before exiting from the isr.
c = input_a();
#int_ext
void int_ext_isr(void)
char c;
c = getc();
int c;
// Clear any pre-existing 'change' condition on
// Port A, and clear the interrupt flags before
// enabling interrupts.
c = input_a();
clear_interrupt(INT_RA);
clear_interrupt(INT_EXT);
// Then enable the interrupts.
enable_interrupts(INT_RA0);
enable_interrupts(INT_EXT);
Note:
There is a bug with the enable_interrupts() function with this PIC with
compiler vs. 3.249. It may also be in vs. 4.xxx -- I haven't checked.
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=26559
It could be fixed by writing your own enable_interrupts() function
or by writing directly to the PIC registers in main(). |
jweller
Posted: Tue Oct 17, 2006 9:02 am |
| My understanding of INT_EXT is that it triggers on any change to input pins. I made a few quick and dirty changes to my code and it does appear to be triggering INT_EXT on both the push button and the rs232 input. It seems as if I have the same problem in a different location. Is there a way to tie INT_EXT to a single pin? If not, I think I am going to try and use kbhit(). |
Posted: Tue Oct 17, 2006 11:34 am |
| Quote: | | My understsanding of INT_EXT is that it triggers on any change to input pins |
EXT_INT only works on the GP2 pin.
From the 12F683 data sheet:
| Quote: |
12.4.1 GP2/INT INTERRUPT
External interrupt on GP2/INT pin is edge-triggered;
either rising if the INTEDG bit (OPTION<6>) is set, or
falling if the INTEDG bit is clear. When a valid edge
appears on the GP2/INT pin, the INTF bit
(INTCON<1>) is set. |
You are thinking of INT_RA and INT_RAx, as shown in my post above.
| Quote: |
12.4.3 GPIO INTERRUPT
An input change on GPIO change sets the GPIF
(INTCON<0>) bit. The interrupt can be enabled/
disabled by setting/clearing the GPIE (INTCON<3>)
bit. Plus, individual pins can be configured through the
IOC register. |
jweller
Posted: Tue Oct 17, 2006 1:11 pm |
| Thanks, I missed that in the datasheet. Problem solved. |
