arunb
| Does this .LST file indicate any problem ?? |
Posted: Tue Oct 03, 2006 5:31 am |
I have this lst file for a PIC project (16F628) does this indicate any problem ???
CCS PCM C Compiler, Version 3.169, 16542
Filename: AnLogger8Chn.LST
ROM used: 1929 (94%)
Largest free fragment is 119
RAM used: 77 (44%) at main() level
90 (51%) worst case
Stack: 5 worst case (3 in main + 2 for interrupts)
thanks
arunb |
Posted: Tue Oct 03, 2006 9:13 am |
No.
However there were problems with the configuration settings for some peripherals on chips like the F628, on earlier compilers, and 3.169, might be old enough for this to apply...
arunb
| RE": |
Posted: Tue Oct 03, 2006 10:58 am |
Thanks for the reply.
Actually I had no trouble with 16F628 and PCM 3.169.
Now I am using 16F648A and PCM 3.228.
I find that whenever 'ROM used' exceeds 'Largest free Fragment' with stack level below 7 , the PIC behaves erratically. Is this normal ?
Could there be a problem in the programmer as well, because now I use my own ICSP based programmer , whereas I used Picstart Plus previously ?
thanks
arunb |
Posted: Tue Oct 03, 2006 2:37 pm |
No, it is not 'normal'.
Check the revision numbers for the chip, there are quite a few erratas for some versions.
Are you just using ICSP, or ICD as well? (if the latter, there is a significant amount at the top of memory, that must not be used to make room for the ICD code). Also is the ICSP, a high voltage or low voltage programmer?. If the latter there is a specific problem with programming some parts of the memory at some voltages on these chips.
