Enable Timer1 interrupt in another ISR?
pe1icq
PostPosted: Fri Sep 29, 2006 10:41 am     Reply with quote
Can I setup and enable a Timer1 interrupt in another ISR?
What I'm trying to accomplish is starting Timer1 in the ISR that handles the PortA change interrupts.
I've tried several things but I can't get it to work.
This is what I have:
#define INTS_PER_MINUTE 114        // (4000000/(4*8*65536)) * 60
int8 minutes;      // A running minutes counter
int8 int_count;    // Number of interrupts left before a minute has elapsed
#PRIORITY TIMER1,RA
#INT_TIMER1                        // This function is called every time
void clock_isr()                   // timer 1 overflows (65535->0), which is
{                                  // approximately 1.9 times per second for
                                   // this program.
    output_high(pin_a3);        // Green LED
    if(--int_count==0) {
        ++minutes;
        int_count = INTS_PER_MINUTE;
    if (minutes==2) {
        output_high(pin_a5);
        // delay_ms(1000);
        // output_low(pin_a5);
#INT_RA
void porta_change_isr()
        delay_us(250);
        if (!input(PIN_A4)) {
                disable_interrupts(INT_TIMER1);
                output_low(pin_a5);             // Red LED
        if (input(PIN_A4)) {
                minutes = 0;
                setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
                set_timer1(0);
                output_high(pin_a5);            // Red LED
        #use fast_io(a)
        input_a();      // dummy read
I can get in an out of the RA ISR. The LED on pin_a5 goes on and off. However Timer1 does not seem to be running, and I never get into the Timer1 ISR (I.e. the debug LED on pin_a3 never goes on)
What am I doing wrong?
BR. //Arno
newguy
PostPosted: Fri Sep 29, 2006 11:25 am     Reply with quote
Stupid question, but did you configure timer 1 to run? ie.
setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);
pe1icq
PostPosted: Fri Sep 29, 2006 12:28 pm     Reply with quote
Yes I did. It is in the #INT_RA ISR.
I also tried putting it in main() but that did not make a difference.
PostPosted: Fri Sep 29, 2006 1:20 pm     Reply with quote
What PIC are you using, and what's your compiler version ?
pe1icq
PostPosted: Fri Sep 29, 2006 1:51 pm     Reply with quote
PIC16F684 and PCM compiler version 3.229 (Linux)
PostPosted: Fri Sep 29, 2006 2:37 pm     Reply with quote
Can you post a main() function, with all of your setup code for the
timer, and the port i/o pins, comparators, etc., ?
Please show the #fuses, #use, and applicable #define statements.
In other words, I want to drop the code into MPLAB and have it compile
with no errors. Then I can look at it.
pe1icq
PostPosted: Fri Sep 29, 2006 2:39 pm     Reply with quote
Well... it would help if I would select a port for the debug LED that actually can be used as an output. RA3 isn't one of those. Embarassed
I swapped RA3 and RA4 and now everything is working fine.
I still have one question. Do I explicitely need to clear the interrupt flags, or does the compiler take care of that for me?
I now have some clear_interrupt() statements in the ISR as shown below. Are those really needed?
#INT_RA
        delay_ms(200);
        if (!input(PIN_A3)) {
        if (input(PIN_A3)) {
                minutes = 0;
                set_timer1(0);
                clear_interrupt(INT_TIMER1);
        clear_interrupt(INT_RA);
newguy
PostPosted: Fri Sep 29, 2006 2:41 pm     Reply with quote
Clearing the interrupt is absolutely required. The compiler doesn't take care of that for you. If a timer is enabled, it will set its overflow flag when it overflows regardless of whether its interrupt is enabled.
Whoops - have to clarify. If you enable the timer interrupt, you must clear any outstanding timer interrupts. As PCM has said, no need to clear the other one - the compiler does that automatically.
PostPosted: Fri Sep 29, 2006 2:55 pm     Reply with quote
You don't need to clear the RA interrupt flag at the end of the isr.
The compiler automatically puts in a line of ASM code to do that for you.
See the lines shown in bold below.
.................... clear_interrupt(INT_RA);
0088: BCF 0B.0.................... }
0089: BCF 0B.0
008A: BCF 0A.3
008B: GOTO 02B
rnielsen
PostPosted: Fri Sep 29, 2006 5:09 pm     Reply with quote
You can turn on/off a timer from anywhere in your code, including an ISR. Simply set/clear the bit that enables the timer.
Ronald
Neutone
PostPosted: Sat Sep 30, 2006 5:12 pm     Reply with quote
                set_timer1(0);
That first line of code will set the counter to zero
the second line will clear the interupt flag that may have already been set by an overflow of timer 1 counter.
The third line will enable interupt if the timer interupt flag is set.
If you dont clear the interupt flag before enabeling the interupt it might jump to the timer 1 interupt routine as soon as it leaves the RA interupt.
