leekp8
| Fuses problem |
Posted: Wed Sep 27, 2006 1:09 am |
I have compilation problem with the following:
#include <18F6527.h>
#fuses HS,NOWDT,PROTECT,NOPUT,NOBROWNOUT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, STREAM=RS485)
#use rs232(baud=9600, xmit=PIN_G1, rcv=PIN_G2, ERRORS, STREAM=UART)
Compilation Output:
Executing: "C:\Program files\Picc\CCSC.exe" "flrwtest.C" +FH +DF +LN +T -A +M +Z +Y=9 +EA
*** Error 111 "E:\ats\A900_WD\BusCard\FLRWTEST\flrwtest.C" Line 4(7,49): Unknown keyword in #FUSES "NOLVP"
1 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Wed Sep 27 15:03:58 2006
If I were to remove NOLVP,
#fuses HS,NOWDT,PROTECT,NOPUT,NOBROWNOUT //,NOLVP
Compilation output will be:
*** Error 111 "E:\ats\A900_WD\BusCard\FLRWTEST\flrwtest.C" Line 4(7,51): Unknown keyword in #FUSES "NOBROWNOUT"
BUILD FAILED: Wed Sep 27 15:08:13 2006
What could be the problem?
Regards! |
Posted: Wed Sep 27, 2006 1:34 am |
It compiles OK with PCH vs. 3.249. What is your compiler version ?
leekp8
Posted: Wed Sep 27, 2006 3:13 am |
| PCM programmer wrote: | It compiles OK with PCH vs. 3.249. What is your compiler version ?
How to check the PCH version?
I also have the PCM install too.
I used with MPLAB. |
stu
Joined: 11 Oct 2006 Posts: 3 Location: south australia
Posted: Thu Oct 12, 2006 12:47 am |
to check the version: under the help tab, click 'about'.
but for the 18f series chips, i believe you will need either the PCH or PCWH compiler. |
Posted: Thu Oct 12, 2006 12:54 am |
| Quote: | How to check the PCH version?
Compile a program (successfully), and then look at the .LST file for
the program. It will be in your project directly. The compiler version
is given at the top of the .LST file. Look for a number like 3.191, or
3.236, or 3.249, etc. |
leekp8
| #fuses problem |
Posted: Thu Oct 12, 2006 1:17 am |
CCS PCH C Compiler, Version 3.235
That was the compiler version. |
Posted: Thu Oct 12, 2006 2:05 am |
I installed PCH vs. 3.235 and it compiles with no errors.
| Quote: |
Loaded C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.cof.
BUILD SUCCEEDED: Thu Oct 12 01:04:21 2006
Here is the program:
| Code: | #include <18F6527.h>
leekp8
| #fuses problem |
Posted: Thu Oct 12, 2006 2:26 am |
I cut and paste your program as below:
The results I got is as follows:
Clean: Deleting intermediary and output files.
Clean: Deleted file "flrwtest.$$$".
Clean: Deleted file "flrwtest.ERR".
Clean Warning: File "E:\ats\A900_WD\BusCard\FLRWTEST\flrwtest.o" doesn't exist.
Clean: Done.
*** Error 111 "E:\ats\A900_WD\BusCard\FLRWTEST\flrwtest.C" Line 3(7,48): Unknown keyword in #FUSES "NOLVP"
BUILD FAILED: Thu Oct 12 16:24:13 2006
What could be the reason?
Regards! |
asmallri
Joined: 12 Aug 2004 Posts: 1663 Location: Perth, Australia
Posted: Thu Oct 12, 2006 2:34 am |
Did you select the device from the config menu? _________________ Regards, Andrew
