wakaka
| PDA PIC control |
Posted: Thu Sep 14, 2006 12:03 am |
Hi there, I'm just wandering that can a PDA (Palm) control a PIC to do simple things like....blinking LED or sensor or hypertermnal???
Is there any available example, training kit or link??
Like I send some commands from a PDA to a PIC, then the PIC will start to blink an LED or do other task.
Wat software should i use for the PDA or wat should be the circuitry?
Of course the code should be written is CCS.
plz help....thanx...... |
asmallri
Joined: 12 Aug 2004 Posts: 1666 Location: Perth, Australia
Posted: Thu Sep 14, 2006 5:32 am |
Palm PDAs have an IR port. You could add an IR interface to the PIC and use this as you communications channel. _________________ Regards, Andrew
wakaka
Posted: Thu Sep 14, 2006 9:04 am |
THanx for the info, is there any example for that??
Any one else has other suggestions? I prefer hard-wired between the PDA(Palm) and the PIC.
thanx |
asmallri
Posted: Thu Sep 14, 2006 9:50 am |
If you search the web you will find stacks of examples for using the Palm asa remote control. You will also find plenty of examples for getting a PIC to respond to RC5 (IR Remote control) sequences. You're now half way there.. _________________ Regards, Andrew
wakaka
Posted: Mon Sep 18, 2006 12:19 am |
I just found one chip, MCP2140 from Microchip. Looks like it can be used for IR communication between PIC and PDA.
But for PDA side, how can i send data? using wat software from PDA?Or the PALM OS has something like the windows hyperterminal?( I haven owned a PDA b4)
Is there any example using MCP2140 with PIC, like blinking an LED or something?
If i wanna use hard wired serial port from PDA, wat software can i use to write data??Hyperterminal for PDA?
For PDA wired serial, the configuration and schematic is it the same as in PC? meaning interface it with a MAX232?
thanx |
Douglas Kennedy
Posted: Mon Sep 18, 2006 8:48 am |
Yes palm PDA's have level shifters ( MAX232 equivalents). To learn it's better to start looking into things yourself. You could have discovered the presence of the level shifter. The PDA is probably using 2.5v to 3.3v so if you see more than that on its serial pins there is a level shifter being used. Your questions are more to do with PDA's than PIC so you will do better searching PDA boards. Palm is a good PDA to use. Palm is public documentation adverse. That means a used Palm is very cheap since most will junk them rather than
try to reverse engineer them. Stay away from Palm's Hotlink it's an exercise in paranoia |
