12f683 printf
oyhan
View user's profile Send private message Send e-mail MSN Messenger
12f683 printf
PostPosted: Sun Sep 03, 2006 12:31 pm     Reply with quote
hi
after this code timeVar=245
I got this message on SIOW TERMINAL
like" *** timePot=255 timeVar=245 *** "
but I have to get timeVar=(255*11)=2805 why? I do not understand..
int16 timeVar=0;
timeVar=(timePot*11);
printf("*** timePot=%u timeVar=%lu ***\n\r",timePot,timeVar);
newguy
PostPosted: Sun Sep 03, 2006 12:54 pm     Reply with quote
Trying casting timePot to an int16 first:
timeVar = (int16)timePot * 11;
oyhan
PostPosted: Sun Sep 03, 2006 1:32 pm     Reply with quote
ok thanks for other form like...
(int8 var1)=(int16 var2) / (int8 var3) is necessary or not..
newguy
PostPosted: Sun Sep 03, 2006 1:53 pm     Reply with quote
You have to be careful with CCS and casting - it can be tricky. I've found that mixing int16's and int8's in formulae is a usually a bad idea.
Whenever I have some calcs that mix 8 & 16 bit values, I always write a test program to see if I get the results I expect to see. If not, casting is always the culprit [rather, how CCS handles casting is different from my idea how it should be handled].
