"Current ICD firmware is not supported"
Jerry Robinson
PostPosted: Wed Aug 23, 2006 4:38 pm     Reply with quote
Using a ICD-U40 with PCWH 3.249 and ICDU.exe dated 4-13-2005. Each time PCWH or icdu.exe tries to access the ICD I get the "Current ICD firmware is not supported" error screen. As far as I know the ICD-U firmware is version 2.05. Anyway I can check this, or, ultimately, fix the problem.
As usual we're down here until we can fix this latest problem.
Thanks for any help
MGP
PostPosted: Sat Aug 26, 2006 9:21 am     Reply with quote
There is a standalone program for the ICD called ICD Control Program. I forget if it's installed with PCWH or separately -- I think you may have to install it separately. It is the standalone programmer and utility software for the ICD.
When you run that program it will show you the current ICD firmware version in the status line at the bottom of the program window.
I just updated all my ICD software a week or two ago. The ICD Control Program version is V2.61 and the ICD Firmware version is V2.09.
So it appears you have older ICD firmware. You can download the current version from the CCS website.
