vinu Guest
| eeprom read -16f690 |
Posted: Tue Aug 22, 2006 5:17 am |
Dear Sir,
is the command "read_eeprom(8-bit address)" work well for 16F690 IC?. I have problems with this particular IC. But the code work well for other IC's like 16F877A. is there any differece in reading eeprom values in 16F690 using CCSC.
Regards,
Vineesh.A |
Fabri
Posted: Tue Aug 22, 2006 9:45 am |
HI Vinu,
The problem, I belive is in configuration memory of device by compiler.
I had the same problem with PCWH V3,235 and PIC16F628 & PIC16F690.
You have to change with device editor the Data EE Type in Memory configuration. you have to change it to normal.
Bye, |
vinu Guest
Posted: Tue Aug 22, 2006 9:52 pm |
Thanks for the valueble information. going to try .
Regards,
vinu |
banic Guest
| eeprom read |
Posted: Fri Nov 03, 2006 6:54 am |
Hello
What is device editor?
Tanks Banic |
Fabri
Posted: Fri Nov 03, 2006 7:03 am |
With device editor you can give some information to your compiler as memory organization, ram, eeprom e so on.
You can found it under "TOOLS" section of compiler IDE.
Regards, |
| Re: eeprom read |
| banic wrote: | Hello
Thanks Banic |
BANIC Guest
| EEPROM |
Posted: Fri Nov 03, 2006 7:06 am |
Hello
I use MPLAB IDE.
Thanks Banic |
Fabri
Posted: Fri Nov 03, 2006 7:10 am |
In any case the CCS compiler use configuration wrote in device editor.
I'm also use MPLAB.
Regards, |
banic Guest
| eeprom |
Posted: Fri Nov 03, 2006 7:30 am |
Hello
Sorry. Not very clear. What program to run? Which button in MPLAB to push?
Thanks Banic |
Fabri
Posted: Fri Nov 03, 2006 7:57 am |
I'm sorry but English is not my language and I can't explain you as I want.
CCS compiler has it's IDE but you can use the compiler directly with MPLAB, as I do.
PCW Compiler IDE start with file "Pcw.exe".
Which version of CCS compiler have you got ?
Regards, |
BANIC Guest
| eeprom |
Posted: Fri Nov 03, 2006 8:33 am |
Hello
I am not a native english. I have not got CCS IDE. I included it in MPLAB.
Still not clear.
Thanks Brano |
Fabri
Posted: Fri Nov 03, 2006 9:13 am |
In the latest MPLAB V7.41 there is a free CCS PCB compiler.
I' can't help you because, at the moment I use MPLAB V7.40 with full version of CCS compiler.
Take a look in help file inside MPLAB
Regards, |
dyeatman
Posted: Fri Nov 03, 2006 11:07 am |
| Unless you have CCS version PCW or PCWH you will NOT have the Device editor. It is ONLY available with the CCS PCW/PCWH IDE and NOT through MPLAB. |
Banic Guest
| eeprom |
Posted: Mon Nov 06, 2006 1:04 am |
Hello
Could someone send me repaired device file related to the eeprom problem?
Thanks b_banic@post.sk |
BANIC Guest
| eeprom |
Posted: Mon Nov 06, 2006 8:01 am |
Hello
I have forgotten the compiler version: PCM 3.225.
Thanks Banic |
