deltatech
| Bitwise Masking wont work Please help ! |
Posted: Wed Aug 16, 2006 1:07 pm |
Hi All i want to extract from this number
19495316080623
194953
and also
1606
I have tried to use bitwise and but it doesnt work .
Can any please tell me what i am doing wrong ?
Thanks in advance
| Code: | #include "F:\Program Files\PICC\Project\MSF\Mask.h"
int received number=19495316080623
int time
int date
time=19495316080623&FFFFFF;
date=19495316080623&000000ff00ff00;
printf(%d,time);
printf(%d,date);
rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
Posted: Wed Aug 16, 2006 1:40 pm |
Normally you perform a bitwise AND on two numbers with a similar radix (i.e. both hex). I'm guessing that doing this with a decimal integer and a hex number means the compiler will likely convert the decimal integer to a hex value, do the AND, then the printf will turn the hex value in to an integer, which will look nothing like your expected result.
In addition, looking at your example, you seem to expect that the bits that are masked out will magically disappear. They don't. If you are ANDing two hex values, the masked bits become zero and are still there. You would need to perform other operations (i.e. right shifts) to extract and use the unmasked bits.
I'm guessing you would likely want to turn your value into an ASCII string and do some C string manipulation instead, but that's not my forte, so I could be wrong. |
rnielsen
Posted: Wed Aug 16, 2006 2:22 pm |
Try using sprintf() to convert the number to a char (or rather a string) and then simply index through the characters, stuffing them where you want, and then convert the string back into an integer.
Ronald |
rwyoung
Posted: Wed Aug 16, 2006 2:25 pm |
Disable HTML when posting code, and continue to use the CODE button.
That said, the code you posted won't compile. The declaration is invalid, you can't have a space in a variable name and the number you are trying to initialize with is greater than 255, the largest 8-bit integer you can have. The default word size is 8-bits for the "int" data type in CCS.
From there it just gets worse. So I'm guessing the problem is your code posting got munged. _________________ Rob Young
