Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Problem with i2c eeprom.. help me...
MONTECCHI lUCA
PostPosted: Sun Jan 12, 2003 6:15 am     Reply with quote
Hi..
I have a problem..
I would like read and write from 16f84 to 24cxx,but I have some problem..
I define the pin for SCL and SDA, and i have use the CCS's driver, but when I use the function read_ext or write_ext in any address, dont write and dont read from Serial eeprom..
Why?
Anyone can help me?
THX!
___________________________
Original Post ID: 10624
Tomi
Re: Problem with i2c eeprom.. help me...
PostPosted: Sun Jan 12, 2003 9:23 am     Reply with quote
1. Do you have pullup resistors on both SCL and SDA?
2. Did you call init_ext_eeprom() from your early main() ?
:=Hi..
:=I have a problem..
:=I would like read and write from 16f84 to 24cxx,but I have some problem..
:=I define the pin for SCL and SDA, and i have use the CCS's driver, but when I use the function read_ext or write_ext in any address, dont write and dont read from Serial eeprom..
:=Why?
:=Anyone can help me?
:=THX!
Original Post ID: 10629
PostPosted: Sun Jan 12, 2003 4:10 pm     Reply with quote
:=Hi..
What compiler are you using ? CCS or CC5x ?
Original Post ID: 10632
MONTECCHI lUCA
PostPosted: Mon Jan 13, 2003 3:08 am     Reply with quote
I use CCS but isn't a last version, is 3.048.
Yes,I call init_ext,but I have connect SDA and SCL to RB7 RB6 without pull-up resistor.. Is this the problem? I must use a 10k resistor?
Original Post ID: 10638
MONTECCHI lUCA
PostPosted: Mon Jan 13, 2003 3:10 am     Reply with quote
CCS,but isn't last version. is 3.048
Original Post ID: 10639
Tomi
PostPosted: Mon Jan 13, 2003 3:39 am     Reply with quote
Yes, you have to use 2.2kOhm or same because those pins are floating.
:=I use CCS but isn't a last version, is 3.048.
:=Yes,I call init_ext,but I have connect SDA and SCL to RB7 RB6 without pull-up resistor.. Is this the problem? I must use a 10k resistor?
Original Post ID: 10640
R.J.Hamlett
PostPosted: Mon Jan 13, 2003 3:47 am     Reply with quote
Yes. I2C, is defined as an 'open collector' drive bus. The chips, provide no 'pull up', and resistors are _required_. The actual value needed will depend on the capacitance of the lines, and the speed required. Normally a value between about 2.2K, and 4.7K, is typical. The bus 'idles' with the lines high, so power is only drawn through the resistors when data is being teansmitted. Without these, the bus will not work.
Original Post ID: 10642
MONTECCHI lUCA
THANKS FOR ALL!! Now read and write OK!!
PostPosted: Tue Jan 14, 2003 1:40 am     Reply with quote
THANKS FOR ALL!!
Original Post ID: 10674
