question on PIC16F876
microccd
PostPosted: Thu Aug 10, 2006 3:20 pm     Reply with quote
I am learning to program the microcontrollers, the following test code works fine on the 16F877 development kit. But it doesn't work on 16F876. Any help will be highly appreciated.
#include <16f876.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT,PUT
#define YELLOW_LED PIN_B4
#define RED_LED PIN_B5
#define PUSH_BUTTON PIN_A4
#define cutoff 128 //2.5 volts
#define neutral_zone 100 //2.0 volts
main() {
   int reading;
   int i;
   setup_adc_ports(RA0_ANALOG);
   set_adc_channel(0);
   output_high(PIN_B4);
   output_high(PIN_B5);
   while(true){
       reading = read_adc();
       if(reading>(cutoff-neutral_zone/2) && reading<(cutoff+neutral_zone/2))
         output_low(PIN_B4);
         i=1;
         output_low(PIN_B5);
         i=2;
       if(i==2)
         while(input(PUSH_BUTTON));
         delay_ms(50);
         while(!input(PUSH_BUTTON));
microccd
PostPosted: Fri Aug 11, 2006 3:24 pm     Reply with quote
help please.
jspencer
PostPosted: Fri Aug 11, 2006 4:18 pm     Reply with quote
It would be better if you posted this in the General CCS Discussion forum. Might try over there.
