help on custom Send_string_RS232 function
Goto page 1, 2  Next
Christophe
PostPosted: Thu Aug 10, 2006 3:41 am     Reply with quote
I want to send a constant string via RS232 that is formatted to our protocol instead of using printf functions.
definition:
#SEPARATE
void Send_String_RS232 (  const char * s , int8 datalength, int8 databyte );
function:
//*************************** Verstuur via RS232 *****************************//
#SEPARATE
   int8 k;
   putc ( 0 );
   putc ( 170 );
   for ( k = 0 ; k < 4 ; k++ )
      putc ( s [k] );
   putc ( datalength );
   if ( datalength )
      putc ( databyte );
use:
#define ADAPTER_IN_COMMANDO "ADIN"
Send_String_RS232 (  ADAPTER_IN_COMMANDO  , 0 ,0 ) ;
Now I get all sorts of compiler errors like declaration of const char * is wrong and " cannot create a pointer to a constant ".
Can you sort this out to get this good? You may not use strcpy functions.
asmallri
PostPosted: Thu Aug 10, 2006 3:47 am     Reply with quote
char const ADAPTER_IN_COMMANDO[] = "ADIN";
Regards, Andrew
PostPosted: Thu Aug 10, 2006 4:16 am     Reply with quote
What are 'datalength', and 'databyte' really needed for?. Will you ever use different values for these?.
You can do something like this:
void putcint(int x) {
   putc(c);
#define Send_String_RS232(x,y,z) putc(0);\
putc(170);\
putcint(x);\
putc ( y ); \
if ( y ) \
      putc ( z );
This however will output the _whole_ of the constant string (not counting four characters as you do).
Working out how it works, I leave down to you... Smile
Christophe
PostPosted: Thu Aug 10, 2006 6:11 am     Reply with quote
I'm afraid that's not working.
This function definition is illegal:
void Send_String_RS232 (const char *  s , int8 datalength, int8 databyte );
There seem to be problems with the const word.
Compiler gives an error: expect ( or '.
I want this:
#define COMMAND "BLAH"
char str [4];
// in program
str = COMMAND;
And yes datalength and databyte are different :-)
asmallri
PostPosted: Thu Aug 10, 2006 6:17 am     Reply with quote
void Send_String_RS232 (char *  s , int8 datalength, int8 databyte );
Regards, Andrew
Christophe
PostPosted: Thu Aug 10, 2006 6:19 am     Reply with quote
still not working that way..
asmallri
PostPosted: Thu Aug 10, 2006 6:31 am     Reply with quote
Sorry for the bum steer. That's what happens when you debug some other problem and try to help someone on the side without giving it your full attention.
I used sprintf to copy the const string to a string and then pass it to printf.
Regards, Andrew
PostPosted: Thu Aug 10, 2006 6:46 am     Reply with quote
   putc(c);
putc(170);\
putcint(x);\
putc ( y ); \
if ( y ) \
      putc ( z );
Modify line 2, to say 'putc(x)', not 'c', and get rid of the last ';' in the define (not needed). It should work.
Christophe
PostPosted: Thu Aug 10, 2006 6:54 am     Reply with quote
I need to send "COMM"
4 bytes.
It don't really understand how
   putc(c);
does that job.
This I want:
0 170 C O M M datalength databyte(s)
normally I always use:
in header file:
#define WAKE_COMMANDO "WAKE"
#define SLEEP_COMMANDO "SLEE"
#define START_LADEN_COMMANDO "LDNG"
in program
printf ("%c%c%S%c",0 ,COMMANDO_BYTE, SLEEP_COMMANDO,0);
Now because I use this printf a lot = much the same code, I want it in a function:
Send_String_RS232 ( string, datalength, databyte )
[/code]
PostPosted: Thu Aug 10, 2006 7:38 am     Reply with quote
The key, is that CCS, has a 'shortcut', for constant strings. If you have a function, that is designed to accept a single byte integer, and you call it, with a constant string, then the function gets automatically called once for every byte in the string. Unfortunately, the 'putc' ciommand as standard, accepts characters, not integers (though they are the 'same' normally in CCS C), this stops the shortcut working.
If you put the putc function into a 'wrapper', that accepts integers:
   putc(c);
Then this 'wrapper', will allow the shortcut to work!.
In fact your initial string can be sent as:
putcint("\000\170COMM");
Details of this shortcut, used to be in the manual, but finding it is 'fun'...
Also, a #define, can be made to behave just like a 'function', with multiple values, and lines in the resulting code, and combined with the shortcut, allows a syntax exactly as you required.
MikeW
PostPosted: Thu Aug 10, 2006 10:01 am     Reply with quote
Ttelmah,
very informative replies from you.
could you elaborate on the quote below, with maybe a few examples
"Also, a #define, can be made to behave just like a 'function', with multiple values, and lines in the resulting code, and combined with the shortcut, allows a syntax exactly as you required. "
Mike
PostPosted: Thu Aug 10, 2006 10:09 am     Reply with quote
I posted a multi-line define to generate the behaviour of the function he wanted.
You can get really 'smart' with defines. For instance, you can use conditional constructs, with multiple statements in the 'test' part of the construct, etc..
These can be a real 'trap for the unwary', but can also be a powerful way of achieving some results.
Christophe
PostPosted: Thu Aug 10, 2006 10:42 am     Reply with quote
All I want is to pass a constant string to a function.
That define-function does not let me change parameters
Send_RS232_String ( constant string, some int, some int);
PostPosted: Thu Aug 10, 2006 11:59 am     Reply with quote
   putc(x);
putc(170);\
putcint(x);\
putc ( y ); \
if ( y ) \
      putc ( z )
Send_String_RS232("COMM",0,0);
Send_String_RS232("Fred",1,2);
Send_String_RS232("Dick,1,0);
What 'more' do you want?.
Christophe
PostPosted: Fri Aug 11, 2006 12:42 am     Reply with quote
Well that is exactly what I want; just I didn't understand that syntax;
What is the meaning of '\' ?
Is that #define line put in the header file?
Can I declare that function in the .C file and put it in the C-program at the bottom?
thks for your input..
Goto page 1, 2  Next
Page 1 of 2
