		| Author | Message |
		| Imanjl
				| INT_RDA  fails when using LCD & delay_ms() function!!!! |
				|  Posted: Tue Aug 08, 2006 3:20 pm |   |
				| Hi guys,, Im using PIC16f877A in some kind of MIDI Controller project,,,I completely confused ..when I send the data to rx pin of 16f877 ,Int_rda doesnt call. with deleting the delay_ms() or also Lcd_putc("test")  the problem solve,,,
 I knew that interrupt calls during the delay execution without using Lcd_putc("test") in the rda_isr() and lcd functions work well without using delay_ms in the main code too .but I want to use both.
 whats the problem,,,,help me plz,
  	  | Code: |  	  | #device adc=8
 #use delay(clock=10000000)
 #fuses NOWDT,HS, NOPUT, NOPROTECT, NODEBUG, BROWNOUT,NOLVP, NOCPD, NOWRT
 #use rs232(baud=31250,parity=N,xmit=PIN_c6,rcv=PIN_c7,bits=8)
 #USE FASt_IO(C)
 #USE FASt_IO(D)
 #include <LCD>
 #int_RDA
 RDA_isr()
 int data,i;
 if (1==1) {data=getc();
 putc(data);}
 lcd_putc("test"); ////problem**
 void main(){
 SET_TRIS_C(0b10100000);
 enable_interrupts(INT_RDA);
 lcd_init() ;
 loop :
 delay_ms(500);             //problem**
 goto loop;
		| PCM programmer
				|  Posted: Tue Aug 08, 2006 3:39 pm |   |
				| The compiler has inserted code to disable interrupts while the delay_ms() function is being executed.
 You can fix this by adding a 2nd #use delay statement right before main()
 as shown below:
  	  | Quote: |  	  | #use delay(clock=10000000)
 void main(){
 However, I believe you may still have problems with the isr because
 you're doing an lcd_putc() for several characters.  Depending on
 how fast that code takes to execute, you may miss incoming chars
 from your UART.
		| Imanjl
				|  Posted: Tue Aug 08, 2006 4:02 pm |   |
				| tnx,,,It works now,,,,the problem solved by inserting #use delay(clock=10000000) ...
 I try delay_US and see that the problem is just with delay_MS i dont know why compiler dont inserted code to disable interrupts in this case .
 I dont have any problem with uart buferring cause it is not all my code and i send a few line ,,,,everything is ok thanks alot helping me
 | You cannot post new topics in this forum You cannot reply to topics in this forum
