I am using a bootloader for the 18F4420 and am using the CCS C Compiler. What instruction do I place in code that will place my starting location of the Main Progran at 0200h in program memory? Is it the #org start,end ?? Is there a instruction where I just give it a starting location only? Purpose is because the bootloader occupies up to 01FFh.
thanks...garry.
asmallri
Joined: 12 Aug 2004 Posts: 1678 Location: Perth, Australia
Posted: Fri Aug 04, 2006 1:43 am
check out the #build directive.
FYI I don't like low memory bootloaders. It forces you to have code that is bootloader aware and it costs additional cycles to process interrupts. _________________ Regards, Andrew
