deneme Guest
| i have freezing prolem |
Posted: Sun Jul 09, 2006 12:51 pm |
i have some design which is added below and code but i have a problem that in high EM field the pic 16f877a can freeze. But ı think i must tell that some of same design was working for a year but some of them are freezing
#if defined(__PCM__)
#include <16F877A>
#fuses HS,WDT,NOPROTECT,NOLVP,NOBROWNOUT
#use delay(clock=4000000 , restart_wdt)
#endif
#include<lcdnewe>
#define parametersAd 8
#define multiplier 16
//pin definition
#define MOTOR PIN_C0
#define FAN PIN_C2
#define CIRCULATION PIN_C3
#define DIRECTION PIN_C4
//pin definition
//time variable
int workTime;
int32 seconds;
int times;
short mode; // surme yada bekleme olması 0 bekleme 1 surme
int timeVariableAdd[2] = {1,2}; // [0] bekleme [1] surme
//time variable
//menu variable
char menuItem[25];
int selection = 0;
int tempVariableAdd[3] = {5,6,7};//0 sirkulasyon,1 durma,2 calışma
char menuIndex[3];
//menu variable
//temp variable
int temp = 0;
int value = 0;
int16 tempSum = 0;
short situation; //0 ust deger altı 1 ust deger ustu
//temp variable
short begining;
short reverse;
int parameters;//situation changed 0,
void readTemp()
restart_wdt();
value = read_adc();
if (tempSum == 0)
tempSum = value;
if (!(value <tempSum> (tempSum / times + 5)))
tempSum += value;
tempSum += (int)(tempSum/(times-1));
restart_wdt();
return;
void menu(int slc)
restart_wdt();
switch(slc)
case 0:
strcpy(menuItem ,"KAZAN SICAKLIK");
strcpy(menuIndex ,"C");
case 1:
strcpy(menuItem ,"BEKLEME SURESI");
strcpy(menuIndex ,"dk");
case 2:
strcpy(menuItem ,"CALISMA SURESI");
strcpy(menuIndex ,"sn");
/* case 3:
strcpy(menuItem ,"BEKLEME SURESI 2");
case 4:
strcpy(menuItem ,"CALISMA SURESI 2");
break;*/
case 3:
strcpy(menuItem ,"SIRKULASYON POMPA");
case 4:
strcpy(menuItem ,"DURMA SICAKLIGI");
case 5:
strcpy(menuItem ,"CALISMA SICAKLIGI");
case 6:
strcpy(menuItem ,"GERI CEVIRME");
strcpy(menuIndex ," ");
restart_wdt();
void controlSituation(int temperature)
parameters = read_eeprom(parametersAd);
restart_wdt();
if( (situation || begining) && read_eeprom(tempVariableAdd[2]) >= temperature)
if(!mode)
situation = 0;
output_high(FAN);
bit_set(parameters,0);
restart_wdt();
write_eeprom(parametersAd,parameters);
restart_wdt();
mode = 0;
begining = 0;
seconds = 0;
if(!situation && (read_eeprom(tempVariableAdd[1]) <temperature>= read_eeprom(tempVariableAdd[0]) && !input(CIRCULATION))
output_high(CIRCULATION);
if (temperature <read_eeprom>= 15)
bit_clear(parameters,0);
restart_wdt();
restart_wdt();
if(read_eeprom(timeVariableAdd[1]))
restart_wdt();
seconds = 0;
restart_wdt();
driveMotor(read_eeprom(timeVariableAdd[1]));
restart_wdt();
return;
if((read_eeprom(timeVariableAdd[mode]) || read_eeprom(timeVariableAdd[!mode])) && !situation)
restart_wdt();
//restart_wdt();
if(mode)
restart_wdt();
if (seconds >= workTime)
restart_wdt();
output_low(MOTOR);
seconds = 0;
mode=!mode;
restart_wdt();
if (seconds >= (int32)(60*(int32)(read_eeprom(timeVariableAdd[mode]))))
restart_wdt();
driveMotor(read_eeprom(timeVariableAdd[!mode]));
restart_wdt();
return;
#INT_RB
void menuItems()
int gecici;
int gecici2;
int tempselection;
int valueb;
valueb = input_b();
delay_ms(40);
if (valueb == input_b())
valueb = valueb - (valueb%16);
restart_wdt();
switch (valueb)
case 0xE0:
if (selection < 3 && selection)
tempselection = selection - 1;
gecici = read_eeprom(timeVariableAdd[tempselection]);
restart_wdt();
if (gecici <255>= 3)
restart_wdt();
if (selection == 6)
reverse = 1;
output_low(MOTOR);
restart_wdt();
output_high(DIRECTION);
restart_wdt();
restart_wdt();
output_high(MOTOR);
restart_wdt();
tempselection = selection - 3;
gecici = read_eeprom(tempVariableAdd[tempselection]);
restart_wdt();
if (selection == 5)
gecici2 = read_eeprom(tempVariableAdd[tempselection - 1]);
if (gecici2 > gecici+1)
++gecici;
write_eeprom(tempVariableAdd[tempselection],gecici);
restart_wdt();
if (gecici < 255)
++gecici;
restart_wdt();
lcd_gotoxy(3,2);
printf(lcd_putc," %u ",gecici);
lcd_gotoxy(9,2);
printf(lcd_putc,menuIndex);
case 0xB0:
if (selection <3> 0)
--gecici;
write_eeprom(timeVariableAdd[tempselection],gecici);
restart_wdt();
lcd_gotoxy(3,2);
if (selection >= 3)
if (selection == 6)
reverse = 1;
restart_wdt();
output_low(MOTOR);
restart_wdt();
restart_wdt();
restart_wdt();
output_high(MOTOR);
restart_wdt();
if (selection == 4)
gecici2 = read_eeprom(tempVariableAdd[tempselection + 1]);
if (gecici2 <gecici> 0)
--gecici;
restart_wdt();
restart_wdt();
if (gecici > 0)
--gecici;
restart_wdt();
restart_wdt();
lcd_gotoxy(3,2);
lcd_gotoxy(9,2);
case 0xD0:
if (selection == 6)
selection = 0;
++selection;
menu(selection);
lcd_putc("\f");
lcd_gotoxy(1,1);
printf(lcd_putc,menuItem);
restart_wdt();
if (!selection)
lcd_gotoxy(3,2);
printf(lcd_putc," %u ",temp);
if (selection <3>= 3)
restart_wdt();
restart_wdt();
lcd_gotoxy(3,2);
lcd_gotoxy(9,2);
if(selection == 6)
lcd_gotoxy(1,2);
lcd_putc(" ");
case 0x00:
restart_wdt();
if (selection == 0)
selection = 6;
--selection;
menu(selection);
lcd_putc("\f");
lcd_gotoxy(1,1);
restart_wdt();
if (!selection)
lcd_gotoxy(3,2);
restart_wdt();
lcd_gotoxy(3,2);
restart_wdt();
lcd_gotoxy(9,2);
if(selection == 6)
lcd_gotoxy(1,2);
lcd_putc(" ");
restart_wdt();
return;
set_tris_b(0xFF);
restart_wdt();
set_timer0(0);
restart_wdt();
setup_timer_0 (RTCC_DIV_256 );
restart_wdt();
enable_interrupts(INT_RB);
restart_wdt();
setup_adc_ports( AN0_AN1_VREF_VREF);
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
restart_wdt();
mode = 0;
times = 0;
seconds = 0;
begining = 1;
reverse = 0;
restart_wdt();
menu(selection);
lcd_putc("\f");
lcd_gotoxy(1,1);
restart_wdt();
delay_ms(50);
readTemp();
lcd_gotoxy(3,2);
printf(lcd_putc," %u ",value);
lcd_gotoxy(9,2);
restart_wdt();
delay_ms(2000);
controlSituation(value);
restart_wdt();
Posted: Sun Jul 09, 2006 2:35 pm |
First comment. Use the 'code' button to post code. Otherwise it is almost unreadable.
The code is too long to look through as a casual search, but one big comment leaps out. Get rid of most of your restart_wdt statements...
You want to make the act of restarting the watchdog, _depend_ on the code running correctly. As it stands, the code can get stuck almost anywhere, and will still keep resetting the watchdog, and will then never recover, making having the watchdog 'pointless'.
Then assuming you are running on 5v, enable the brownout restart as well.
deneme Guest
| still have problem |
Posted: Tue Jul 25, 2006 11:21 am |
I applied the suggestions Ttelmah but it still freezing but I want to remind that I have some of this design and same program running about a year
I send the code again
| Code: | #if defined(__PCM__)
#include <16F877>
#fuses HS,WDT,NOPROTECT,NOLVP,BROWNOUT
#use delay(clock=4096000 , restart_wdt)
#endif
#include<lcdnewe>
//pin definition
#define FAN PIN_C2
//pin definition
//time variable
int workTime;
int32 seconds;
int times;
//time variable
//menu variable
char menuItem[25];
int selection = 0;
char menuIndex[3];
//menu variable
//temp variable
int temp = 0;
int value = 0;
int16 tempSum = 0;
//temp variable
short begining;
short reverse;
void readTemp()
value = read_adc();
if (tempSum == 0)
tempSum = value;
tempSum += value;
return;
void menu(int slc)
switch(slc)
case 0:
case 1:
case 2:
/* case 3:
case 4:
break;*/
case 3:
case 4:
case 5:
case 6:
if(!mode)
situation = 0;
output_high(FAN);
mode = 0;
begining = 0;
seconds = 0;
seconds = 0;
return;
if(mode)
output_low(MOTOR);
seconds = 0;
mode=!mode;
return;
#INT_RB
void menuItems()
int gecici;
int gecici2;
int tempselection;
int valueb;
restart_wdt();
valueb = input_b();
delay_ms(40);
switch (valueb)
case 0xE0:
if (selection == 6)
reverse = 1;
output_low(MOTOR);
output_high(MOTOR);
if (selection == 5)
++gecici;
if (gecici < 255)
++gecici;
lcd_gotoxy(3,2);
lcd_gotoxy(9,2);
case 0xB0:
--gecici;
lcd_gotoxy(3,2);
if (selection >= 3)
if (selection == 6)
reverse = 1;
output_low(MOTOR);
output_high(MOTOR);
if (selection == 4)
--gecici;
if (gecici > 0)
--gecici;
lcd_gotoxy(3,2);
lcd_gotoxy(9,2);
case 0xD0:
if (selection == 6)
selection = 0;
++selection;
menu(selection);
lcd_putc("\f");
lcd_gotoxy(1,1);
if (!selection)
lcd_gotoxy(3,2);
lcd_gotoxy(3,2);
lcd_gotoxy(9,2);
if(selection == 6)
lcd_gotoxy(1,2);
lcd_putc(" ");
case 0x00:
if (selection == 0)
selection = 6;
--selection;
menu(selection);
lcd_putc("\f");
lcd_gotoxy(1,1);
if (!selection)
lcd_gotoxy(3,2);
lcd_gotoxy(3,2);
lcd_gotoxy(9,2);
if(selection == 6)
lcd_gotoxy(1,2);
lcd_putc(" ");
restart_wdt();
return;
set_tris_b(0xFF);
set_timer0(0);
restart_wdt();
mode = 0;
times = 0;
seconds = 0;
begining = 1;
reverse = 0;
menu(selection);
lcd_putc("\f");
lcd_gotoxy(1,1);
delay_ms(50);
readTemp();
lcd_gotoxy(3,2);
lcd_gotoxy(9,2);
restart_wdt();
delay_ms(2000);
restart_wdt();
restart_wdt();
rnielsen
Posted: Tue Jul 25, 2006 1:52 pm |
I'm not sure if this would cause your lock-ups but this code doesn't look quite right to me, not that I'm the resident expert on proper coding.
| Quote: | | if(!situation && (read_eeprom(tempVariableAdd[1]) <temperature>= |
and
| Quote: | | if (temperature <read_eeprom>= 15) |
Your evaluations don't look like I would think they should. Plus, the second quote would indicate that you have a variable named 'read_eeprom' which is also an internal command, that you are also using, to read the eeprom. But then I stink at reading other peoples messes, let alone my own.
Ronald |
Posted: Tue Jul 25, 2006 2:37 pm |
It's because the post was done with HTML enabled. It used to be
disabled by default and recently all posts have it enabled by default,
which causes many posts to have scrambled code. Before you post,
look below the text box in the posting window. You'll see this:
| Code: | | Disable HTML in this post |
Make sure it is selected.
Darren has said he will try to look into this problem later this week.
CCS is currently consumed with the version 4.0 beta rollout. |
libor
Posted: Thu Jul 27, 2006 7:02 pm |
| Quote: | | I have freezing problem |
| Code: | while (1) {
if (temperature < 0) {
output_high(HEATER_CONTROL_PORT) ;
} else {
output_low(HEATER_CONTROL_PORT);
This'll help you, no freezing any more... Guaranteed. (...you might want to add some hysteresis) (sorry :-) |
