asmallri
Joined: 12 Aug 2004 Posts: 1678 Location: Perth, Australia
Posted: Fri Jul 21, 2006 6:30 pm |
This will work however - I would increase the 10K to 47K and I would decrease the 10M to 1M. You do not actually need the zener because the input protection diode of the PIC and the 47K resistor limit the current into the PIC.
An simpler alternative is to remove the input diode and replace the zener with a normal diode. _________________ Regards, Andrew
