arrow
| MMC/ SD Current Drawn upon Write? |
Posted: Fri Jul 21, 2006 8:06 am |
Hi
I was wondering if anyone could tell me what is the minimum current draw upon writting either to a MMC or SD cards?
I am planning to use Lithium 3V coin cell batteries and was wondering if these are powerful enough to do the write operation to MMC / SD?
Thank you in advance
a. |
epideath
Posted: Fri Jul 21, 2006 9:00 am |
Well according to the datasheet the current draw max at 3.6V are:
READ - 50ma
WRITE - 60ma
SLEEP - 150uA
Regards |
arrow
Posted: Fri Jul 21, 2006 9:15 am |
Hi Epideath
Thank you- I am looking for these data sheets.
Can you please direct me to a link?
Regards
a. |
epideath
arrow
Posted: Mon Jul 24, 2006 1:08 am |
Hi Epideath
Thank you very much! That is most helpful.
May I ask you before I start the development: I am going to try and
power my circuit with coin cell batteries (Lithium 2032).
I am wondering if these coin cells can be used to write (block write) to a MiniSanDisk card? and if so, for how long?
I was thinking of after every block write to have the card go to sleep. Thus if I have 4 block writes/second it would be a very small duty cycle, but is the coin cell battery powerful enough to do the writting?
Once again thank you- I appreciate it!
Regards
a. |
asmallri
Joined: 12 Aug 2004 Posts: 1666 Location: Perth, Australia
Posted: Mon Jul 24, 2006 4:47 am |
| arrow wrote: | | May I ask you before I start the development: I am going to try and power my circuit with coin cell batteries (Lithium 2032). |
Read the datasheet for the battery and get the battery capacity.
| Quote: | | I am wondering if these coin cells can be used to write (block write) to a MiniSanDisk card? and if so, for how long? |
You can capculate this from the write figures given to you and the battery capacity information.
| Quote: | | I was thinking of after every block write to have the card go to sleep. Thus if I have 4 block writes/second it would be a very small duty cycle, |
You will need to check the datasheet but from memory - it can take 500ms for the card to become active from powered down state. From idle state it takes about 5ms worst case. I do not remember how you put the card to sleep - I think it is just by keeping it inactive for a few milliseconds _________________ Regards, Andrew
