mbge5amw
Joined: 13 Dec 2004 Posts: 15 Location: Yorkshire, UK
| changing format of __DATE__ |
Posted: Wed Jul 19, 2006 3:26 am |
Is there a better way of doing this:
I wish to have a string containing the compile date in dd/mm/yy format.
I have written a very Heath Robinson routine that takes __DATE__ in its format 17-Jul-06 and changes it to 17/07/06 but this routine uses up valuable ROM and RAM.
Is there any way of getting this conversion to be performed automatically at compile time?
TIA
Andy
void generate_version( void )
int8 local_date_t;
int8 local_date_u;
int8 local_month_t;
int8 local_month_u;
int8 local_year_t;
int8 local_year_u;
strcpy (motor_compile_date,__DATE__);
local_date_t = motor_compile_date[0];
local_date_u = motor_compile_date[1];
local_year_t = motor_compile_date[7];
local_year_u = motor_compile_date[8];
switch(motor_compile_date[3])
case 'J':
switch(motor_compile_date[4])
case 'a': //jan
local_month_t = '0';
local_month_u = '1';
case 'u':
switch(motor_compile_date[5])
case 'n': //jun
local_month_u = '6';
case 'l': //jul
local_month_u = '7';
case 'F': // feb
local_month_u = '2';
case 'M':
case 'a':
case 'r': //mar
local_month_u = '3';
case 'y': //may
local_month_u = '5';
case 'A':
case 'p': //apr
local_month_u = '4';
case 'u': //aug
local_month_u = '8';
case 'S': // sep
local_month_u = '9';
case 'O': // oct
local_month_t = '1';
local_month_u = '0';
case 'N': // nov
case 'D': // dec
motor_version[0]='v';
motor_version[1]='e';
motor_version[2]='r';
motor_version[3]=':';
motor_version[4]=' ';
motor_version[5] = ((local_date_t & 0x0f) << 4) + (local_date_u & 0x0f);
motor_version[6] = ((local_month_t & 0x0f) << 4) + (local_month_u & 0x0f);
motor_version[7] = ((local_year_t & 0x0f) << 4) + (local_year_u & 0x0f);
Posted: Wed Jul 19, 2006 6:26 am |
Unfortunately, I can't think of any truly 'better' way of doing this. The problem is that '__date__' is a pre-processor defintion, replaced as a constant string with the 'date'. All string comparisons/manipulations, are C operators, not preprocessor operators.
Personally, given that the 'date', is the compile date, and not something that should change in normal use, I'd do the following:
Firstly, just define your own constant at the start of the source, something like:
#define mdate 17/07/06
and make a point for now of changing this whenever you re-compile.
Then secondly, ask CCS, to consider generating a new '__numdate__' definition to the compiler, or a flag to switch the format of the 'date data'. This should be pretty easy for them to do, and could be of use to other people.
