KamPutty Guest
| Linux? |
Posted: Tue Jul 18, 2006 10:11 am |
Hi all,
Well, I may be moving some of my development platforms back to Linux. I have been currently using Windows XP.
I own version 3.234 for all 3 compilers (windows version)
I own the MachX
So my question is, does CCS REALLY support Linux with up-to-date drivers, software etc? How much of what I've purchased is lost? Meaning that it will not work with Linux.
Any thoughts?
~Kam (^8* |
alanp
Posted: Tue Jul 18, 2006 2:58 pm |
Hi there,
I have the command line version of PCM and just going through the same move myself. I spoke to CCS and they replied saying that I could buy the maintainance contact for $99 to get the linux version.
I have played with it a little on linux. It does work under Wine so I will carry on with that for a little while before deciding whether to spend the extra money to get the full blown version.
Cheers |
Storic
Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
Posted: Tue Jul 18, 2006 4:57 pm |
I could not get my version to work under linix/wine. what version linix and wine are you using.
I would like to work under linix, yes I will also get the software for linix in due course, I am waiting for after V4 release so I can look at the dsPIC and 24F micros before the jump to linix software.
Andrew  _________________ What has been learnt if you make the same mistake?
asmallri
Joined: 12 Aug 2004 Posts: 1664 Location: Perth, Australia
Posted: Wed Jul 19, 2006 12:44 am |
| alanp wrote: | Hi there,
Cheers |
I received a different reponse when I wanted to move from my 1 month old version of PCH to Linux (was still under maintenance at the time). I was told I would have to buy the Linux version. _________________ Regards, Andrew
MikeValencia
Posted: Wed Jul 19, 2006 8:44 am |
Regarding the compiler:
I was told that i would have to buy a new version of PCHL altogether, despite the fact that i have a pch and pcwh subscription already.
Regarding drivers and programming:
You have to email support in order to get the executables/drivers you need in order to use a MACHX or ICDU40. They are free by request, but not available on the website for downloading.
As for my experience trying to get it to work, tech support has been responsive, yet I still can't get it to work! First I tried it with Linspire Linux and also with Ubuntu Linux. I made the symbolic link from ttyUSB0 to ttyS0, yet I still can't get it to work. Now, in fact, everytime I invoke the executable, it just freezes, as if I corrupted something since the last time.
If your "core competency" is being an embedded software engineer, then I suggest you stick with Windows for your host platform. I've lost many hours of productivity trying to embrace Linux over and over again. Back in the days when I used Solaris/Unix at work, we had systems administrators and people assigned administrate the makefiles and directories. All I had to worry about was writing C code and typing in "make all" at the end. With Linux, you have to spend a lot of time in community forums asking for help to get a plugin to work, and you have to wear the hat of sys admin at the same time. After all that, you realize your ICD still doesn't work right under Linux, so you go back to your trusted WinXP computer in order to get some real work done. |
alanp
Posted: Wed Jul 19, 2006 3:05 pm |
I'm running gentoo 2.6.16-gentoo-r7 with Wine 0.9.8. I got PCM 3.224 runnning with not too many problems. I don't think that I had to do too much in Wine to get it running.
Hope this helps
Cheers |
Storic
Posted: Wed Jul 19, 2006 4:32 pm |
| alanp wrote: | I'm running gentoo 2.6.16-gentoo-r7 with Wine 0.9.8. I got PCM 3.224 running with not too many problems. I don't think that I had to do too much in Wine to get it running.
Hope this helps
Cheers |
Thanks, I will give it a go
yes MikeValencia I to had spend many hours trying to get linix/wine to work with my WinXP. I do maintain a system running under UNIX and every time I have to go into UNIX I pray the information I need to do is correct. I have been caught out where I a 1 hour job turned into a 2 day event.
Andrew _________________ What has been learnt if you make the same mistake?  |
