In my program I use a driver (suppose whose name is red.c).
In red.c file there is the instruction:
#include<red>
which contains defs for the driver.
May I put that instruction in main file and cancel from red.c?
I need to put one function (contained in red.c) in main file and to go on using the other functions contained in red.c file.
Does it work?
Thank you
asmallri
Joined: 12 Aug 2004 Posts: 1675 Location: Perth, Australia
Posted: Fri Jul 14, 2006 5:12 am
If you place the code in red.c inplace of the liine with the include statement then the code compiled will be identical. _________________ Regards, Andrew
