Markdem
| Problem with CDC driver |
Posted: Wed Jul 12, 2006 4:34 am |
Hi All, i have decided that my fish tank conntroller that i am building need to have USB support. Anyway, i am using a PIC18F4550 with the usb_serial example. When i plug the usb cable in, windows detects the device as unknown, and then fails to install saying that the device has malfunctioned. I then tired to install the cdc driver, but windows tells me that the file does not contan any information about my device. I have also tried to install the driver by right clicking on it, but it did not help.
I have three questions about the usb_serial example;
1. are the internal pullups enabled and
2. in the internal 3.3 regulator enabled and
3. I am using a 20MHz cryistal. Is this OK?
Can anybode shed some light on my problem??
Thanks, Mark |
jspencer
Joined: 22 Dec 2003 Posts: 57 Location: Boise, ID USA
| Re: Problem with CDC driver |
Posted: Wed Jul 12, 2006 9:26 am |
| Markdem wrote: |
Thanks, Mark |
1. I can't remember if the pullups are enabled by default or not, but if you want to be sure then in your main enable or disable them.
2. If you didn't mess with any of the code below, then yes the 3.3V internal regulator is enabled.
3. Again, if you didn't mess with the code below then the 20MHz crystal is fine. Because of the fuses that are set it uses the 20MHz input and the internal PLL to set the clock speed at: clock=48000000 (48MHz)
#define __USB_PIC_PERIF__ 1
#if !defined(__PCH__)
#error USB CDC Library requires PIC18
#if __USB_PIC_PERIF__
#DEFINE LED1 PIN_A5
#include <18F4550>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
/// Ignore the code from here down as you are not using this chip
#else //use the National USBN960x peripheral
#DEFINE LED1 PIN_B3
#include <18F452>
#endif //endif check to see which peripheral to use
Markdem
Posted: Wed Jul 12, 2006 3:57 pm |
thanks jspencer. but i am still having problems. It almost looks like more of a windows issue then a pic issue. I have now tried installing it on 2 diffrent computers, and all of them tell me that the device has malfunctioned. Has anyone else had this problem or suggest what i can do to try to fix it.
Thanks, Mark |
jspencer
Posted: Wed Jul 12, 2006 4:38 pm |
One other thing, CCS uses the default product and vendor ids for both the two different types of USB devices that I've used (CDC and HID). If you have installed used the HID device and then try to use the CDC device without uninstalling the HID device or changing the Product ID (usb_cdc_desc file), windows thinks that it is still and HID device. Open your device manager, right click on My Computer and select properties, then select device manager. Under the device (HID or COM port) you can look at the VID and PID for the device. Since there is an error with the device you should have a device in the list with a yellow circle with a question mark in it. Try uninstalling it and then unplug the usb cable, wait a few seconds and then plug it back in and see if it fixes your problem.
This may not be the problem, but is something I ran into when we ported our product from an HID device to a CDC device.
One more note, make sure that the PID and VID values that are in the CDC driver match the values that are in the usb_cdc_desc file.h file. |
Markdem
Posted: Wed Jul 12, 2006 7:14 pm |
Thanks again for you suggestions. Should the cdc drivers just work without me changing them??
anyways, i have checked PID and VID of the driver and usb_desc_dcd. Can you please tell me if they are correct. it looks like they have to be read from left to right.
cdc_NTXP.inf
[ccs]
%CCS_CDC%=Reader, USB\VID_0461&PID_0033
usb_desc_cdc.h
0x61,0x04, //vendor id
0x33,0x00, //product id
Thanks again for your help
Mark |
Markdem
Posted: Thu Jul 13, 2006 5:40 am |
OK, i have done some more testing, and i think it may be my hardware.
When i look at device manager, the pid and vid are 0000, which i am going to guess is incorrect. Also, if i swap the d+ and d- pins on the pic, the PC will still see the device and give me the same error.
At this point I have two more questions..
1. I have looked at a lot of USB designs on the web, and all the connections between the PC and pic all seem to be diffrent. My connections looks like the following, is it correct??
| Code: | USB Connector PIC
PIN1(5v) (This pin is not connected to anything on my PIC board)
PIN2(D-) PIN_C4
PIN3(D+) PIN_C5
PIN4(GRD) Device ground |
2.How do I enable the internal pullups? I have read the dtasheet, and know the register i need to change, but i am new to this and have never changed a register myself. How do I go about it.
Thanks again
mark |
Markdem
Posted: Thu Jul 13, 2006 5:57 am |
One more problem, when i compile the code i get the following warning
Warning 202 "C:\PROGRA~1\PICC\drivers\usb_desc_cdc.h" Line 147(16,37): Variable never used: USB_CLASS_DESCRIPTORS
Is this somthing that i should care about??
Thanks, Mark |
jspencer
Posted: Thu Jul 13, 2006 11:04 am |
The PID and VID look good. The pin out looks good for the USB and since you do not have +5 connected to anything, I'm assuming that your board is self powered. As for the pullups the quote below was taken directly from the CCS manual. Replace x with the port that you need to pullup. Just make sure that the pullups are available for the port that you are using.
| Quote: |
PORT_X_PULLUPS
Syntax:
port_x_pullups (value)
Parameters:
value is TRUE or FALSE on most parts, some parts that allow pullups to be specified on individual pins permit an 8 bit int here, one bit for each port pin.
Returns:
undefined
Function:
Sets the port A input pullups. TRUE will activate, and a FALSE will deactivate.
Availability:
Only 14 and 16 bit devices (PCM and PCH). (Note: use SETUP_COUNTERS on PCB parts).
Requires
Nothing
Examples:
port_a_pullups(FALSE);
Example Files:
ex_lcdkb.c with kbd.c
Also See:
input(), input_x(), output_float()
What size cap do you have on the Vusb line? You should have a 0.47uF cap to ground on that line.
The warning you are getting I'm not sure about. What version of the compiler are you using? That might help. I used 3.239 and it is compiling fine. |
Markdem
Posted: Thu Jul 13, 2006 4:09 pm |
Thanks for your help jspencer, what do you mean Vusb. Do you mean the 5v+ line that is coming from my PC? I dont currently have any caps there. I will try tonight.
my compiler version is 3.236. Maybe there could be a problem there. Is it possible, if it is not too much hassle, that you could email me your hex file. That way, at least i will stop wasting time trying to fix this.
My address is markdem(at)optushome.com.au
thank you again for your help.
Mark |
jspencer
Posted: Thu Jul 13, 2006 4:19 pm |
| C3/Vusb needs a 0.47uF cap on it. This is for the USB voltage regualtor. |
Markdem
Posted: Sun Jul 16, 2006 7:13 pm |
Thankyou so much jspencer, i dont know how i missed that. It all looks good now
Thanks, Mark |
