EEPROM reading ...
prayami
EEPROM reading ...
PostPosted: Wed Jul 05, 2006 8:49 pm     Reply with quote
Hi...
As per I know there is no endurance for reading EEPROM. But as we are
going to release new product ,just want to confirm with masters.
I read in the data sheet about erase/write endurance for EEPROM.
That, I have taken care for writting EEPROM.
But there is nothing in the datasheet for reading EEPROM.
Is there any issue/drama for reading EEPROM in the loop for a number
of times in any circumtances whether cold or what ever....
Thanks.....
asmallri
PostPosted: Wed Jul 05, 2006 9:23 pm     Reply with quote
No issue in general however there was a silicon bug with some PICs at one time that could result in an incorrect value being read back from EEPROM. Check the Errata for your PIC.
Regards, Andrew
rnielsen
PostPosted: Thu Jul 06, 2006 8:44 am     Reply with quote
I don't believe there is a maximum number of 'reads' that can be made from an eeprom. If you are reading a boat load and only writing a little then you should be fine. It's if you write a boat load that will cause the eeprom to die.
Ronald
Mark
PostPosted: Thu Jul 06, 2006 11:47 am     Reply with quote
Still on the first page of posts!
http://www.ccsinfo.com/forum/viewtopic.php?t=27480
