MachX stopped programming from within IDE...
kam
PostPosted: Fri Jun 23, 2006 6:51 pm     Reply with quote
Hi all,
I just upgaded my fireware on my MachX, to version 1.78 (latest). I can program my target chip (pic18f4520) on the ccs software protoboard just fine from within the MachX application.
Now, I cannot program the chip from within CCS's IDE! That has stopped sincemy upgrade just a few bits ago...! ahhh!
I can debug just fine! go figure...
Any thoughts?!
~Kam (^8*
kam
PostPosted: Sat Jun 24, 2006 10:21 am     Reply with quote
My versions for IDE/Compilers are 3.234...
kam
Heads up!
PostPosted: Tue Jun 27, 2006 10:11 am     Reply with quote
Hi all,
Well, after speaking with CCS tech support, this is the issue.
Version 1.78 needs an additional command line arg from the IDE to tell how to program (zif, icsp etc).
" We have added a third command line parameter to specify if the zif socket or the icd jack is to be used. It can be 0 or 1 or 2 as explained below
0- zif socket(this is by default)
1- icd jack with power supplied from machx
2 -icd jack with no power supplied form machx
So try "C:\PROGRA~1\PICC\MACHX.EXE" "-T%H" "%D" 1 - board not powered externally
or "C:\PROGRA~1\PICC\MACHX.EXE" "-T%H" "%D" 2 - board powered on its own"
Version 1.71 did not need this...
~Kam (^8*
