Channing
| Need to combine multiple chars to string then float |
Posted: Fri Jun 23, 2006 3:00 pm |
I have a program that reads in data from a digital protractor via serial. I already have the receive functions setup and working properly. The protractor sends the angle one 'number' at a time, i.e. 123.45 degrees is sent as a 1, then a 2, then a 3, then a ".", then 4, then 5, and I have each number assigned to a variable, ang_hun_bit, ang_ten_bit, and so on.
What I need to do is convert these chars to a useable number to average and check.
I know there is the atof() function to convert a string to a float, but I can't get the chars combined to one string. Here is my code so far:
[/code]
float parse(char *hun, char *ten, char *one, char *tenth, char *hundth)
char data_string[8];
float runner;
char *ptr;
// ptr = data_string;
ptr = strcpy(data_string, hun);
ptr = strcat(data_string, ten);
ptr = strcat(data_string, one);
ptr = strcat(data_string, decimal);
ptr = strcat(data_string, tenth);
ptr = strcat(data_string, hundth);
lcd_gotoxy(1,2);
printf(lcd_putc,"%6s", ptr);
runner = atof(ptr);
// lcd_gotoxy(1,2);
// printf(lcd_putc,"%f", runner);
average += runner;
avg_counter++;
return runner;
}[/code]
I am passing all of the individual numbers of the measurement sent by the protractor into this function. The pointers are working correctly as I can print each indiviudally via printf(lcd_putc, "%c%c%c.%c%c", [variable list].
Thanks for your help[/code] |
Posted: Fri Jun 23, 2006 3:49 pm |
You're treating each incoming character as if it's a separate string.
I really doubt that this is how the instrument sends the data.
Can you post a link to the unit's manual, which describes the protocol
in detail ? |
epideath
Posted: Fri Jun 23, 2006 3:59 pm |
One way that you could accomplish this, if you always get charaters for each digit sould be to do something like this:
char data_string[8] = " "; // 7 spaces allowing 1 for the 0x00
data_string[0] = hun;
data_string[1] = ten;
data_string[2] = one;
data_string[3] = '.';
data_string[4] = teth;
data_string[5] = hundrth;
data_string[6] = 0x00;
runner = atof(data_string);
but this would be better if you did it in the function where you are actually reading the data in.
you could do something like:
for(i=0; i<6; i++)
data_string[i] = read_char();
There are many other ways to accomplish this using the strcpy and strcat functions also.
hope this helps |
Humberto
Posted: Fri Jun 23, 2006 9:37 pm |
Once I had a similar problem with a magnetic compass. The problem was that the output
string doesn´t keep the same size, instead it depends of the value.
Typical output string format was as follow:
<sign> XXX.XX <CR> <LF>
+ 123.40 <CR> <LF>
- 12.30 <CR> <LF>
+ 5.45 <CR> <LF>
Normally to cover the full 360 degree, the range and the readout is between -180 deg. and +180 deg.
You must store the incoming chars in a buffer, then in main the first task is to know the "size" of
the incoming value, I solved it looking where was stored the delimiter 'point', (I mean in wich buffer position.)
Also you can use the atof() function to convert a string to a float, to compare if it generate a shorter code,
but this is your job.
NOTE: Following code not tested, just to show you how I did it.
#define point '.'
#define plus '+'
#define minus '-'
int8 hun, ten, one, teth, hundrth;
char start_of_string;
float Ftotal;
start_of_string = FALSE;
if((data[0] == plus) || (data[0] == minus))
sign = (data[0]; // always the first char is the sign
if(data[4] == point)
hun = (data[1] & 0x0F) * 100 ; // max expected value is 100
ten = (data[2] & 0x0F) * 10;
one = (data[3] & 0x0F);
total_integer = (hun + ten + one);
teth = (data[5] & 0x0F);
(float) teth = (float) teth / 10.0;
hundrth = (data[6] & 0x0F);
(float) hundrth = (float) hundrth / 100.0;
if(data[3] == point)
ten = (data[1] & 0x0F) * 10;
one = (data[2] & 0x0F);
total_integer = ( ten + one);
teth = (data[4] & 0x0F);
hundrth = (data[5] & 0x0F);
if(data[2] == point)
one = (data[1] & 0x0F);
total_integer = one;
teth = (data[3] & 0x0F);
hundrth = (data[4] & 0x0F);
(float) Ftotal = ( (float) total_integer + (float) hundrth + (float) teth);
Hope you understand the idea.
Humberto |
Channing
| Thanks guys |
Posted: Mon Jun 26, 2006 8:34 am |
I just simply assigned the individual pointers to each element of the array, and now I have 100% precision (or as close as I am going to attempt to get).
As they always say, sometimes is just take a second opinion on code, to step away and come back.
Thanks again guys for the help. I am sure I will be back for more help with future projects. |
