Wireless serial comunication.
fuzzy
PostPosted: Tue Jun 20, 2006 5:19 pm     Reply with quote
I've read all posts of this forum about wireless comunication between PICS but i still can't interface them.
I've already used RS232 communication between PIC with good results. Now i'm trying to do it using FSK 433MHZ modules. I try to send one or more caracthers from Transimmetr and apparently it seems send something. But receiver can't get data. I used both INT_RDA or KBHIT without results. Using INT_RDA as i power up receiver it enter in interrupt routine even if transmitter is off. when i put on transmitter it sends but receiver doesn''t receive what i want . i don't know if it receive and if it enter again in interrupt routine.
I'll put her my code: TX
#include <16f88.h>
#fuses INTRC, NOPROTECT, NOPUT, NOWDT, MCLR, NOLVP , NOBROWNOUT
#use delay(clock = 4000000)
//#use fast_io(A)
//#use fast_io(B)
#use rs232(baud=2400, xmit=PIN_B5,rcv=PIN_B2, PARITY=e )
#define INTS_PER_1S 488     // (8000000/(4*16*256))
BYTE seconds;      // A running seconds counter
BYTE int_count;    // Number of interrupts left before a second has elapsed
char codice=8;
char premuto=0;
#int_rtcc                          // This function is called every time
void clock_isr() {                 // the RTCC (timer0) overflows (255->0).
                                   // For this program this is apx 60 times
    if(--int_count==0)             // per second.
      int_count=INTS_PER_1S;
main(void)
SET_TRIS_A(0b11111101);
SET_TRIS_B(0b11011111);
SETUP_ADC(ADC_OFF);
SETUP_ADC_PORTS(NO_ANALOGS);
output_low(PIN_A1);
output_high(PIN_B5);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_oscillator(OSC_8MHZ);
//setup_wdt(WDT_576MS);
   set_timer0(0);
   setup_counters( RTCC_INTERNAL, RTCC_DIV_16);
   enable_interrupts(INT_RTCC);
delay_ms(25);
 premuto=0b10101010;
 while ( !input(PIN_B1) )
    printf("%C",premuto);
     OUTPUT_toggle(PIN_A1);
     delay_us(10);
RX
#include <16f88.h>
//#use fast_io(A)
//#use fast_io(B)
char codice=0;
char comando=0;
int t;
#define BUFFER_SIZE 30
char buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
    buffer[next_in]=0;
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
    codice=buffer[next_in];
    comando=getc();
  output_high(PIN_A2);
  if (comando==0b10101010)
   output_high(PIN_B3);
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
main()
SET_TRIS_A(0b00000000);
SET_TRIS_B(0b00000100);
SETUP_ADC(ADC_OFF);
buffer[12]=0;
   setup_spi(FALSE);
   set_timer0(0);
  enable_interrupts(INT_RDA);
/*  if(kbhit())
    comando=getc();
   output_toggle(PIN_B3);
  if (comando!=0)
if(comando== 0b10101010)
 output_high(PIN_A1);
 //else
// output_low(PIN_A1);
i'm sorry it is a little confused but i made several tests.
what should i change??
newguy
PostPosted: Tue Jun 20, 2006 5:43 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=23953
fuzzy
PostPosted: Wed Jun 21, 2006 2:56 am     Reply with quote
Thanks but as I sayed I already read that post. I took my inspiration from it.
I also tryed it in my device without success:
RX
#include <16F88.h>
#define Fosc 40000000
#define WireTX PIN_B5
#define WireRX PIN_B2
#use delay(clock = Fosc,RESTART_WDT)
#fuses INTRC, NOPROTECT, NOPUT, NOWDT,  NOLVP , NOBROWNOUT
#use rs232(baud=9600, xmit=WireTX, rcv=WireRX, ERRORS, STREAM=Wireless)
#define RX_BUFFER_SIZE 40
#define TX_BUFFER_SIZE 40
int8 rx_wr_index = 0, tx_rd_index = 0, tx_wr_index = 0, tx_counter = 0, received = 0;
int8 lock_state = 0, rxd, i, valid_data_count;
unsigned int8 rx_buffer[RX_BUFFER_SIZE + 1], tx_buffer[TX_BUFFER_SIZE + 1];
int1 data_avail = FALSE, got_id = FALSE;
#int_RDA
void RDA_isr(void) {
   rx_buffer[rx_wr_index] = getc();
   rxd = rx_buffer[rx_wr_index]; // this just makes it easier typing-wise later on
   rx_wr_index++;
   if (rx_wr_index > RX_BUFFER_SIZE) {
      rx_wr_index = 0;
   // now look for unique ID: "Dave "
   if (rxd == 'D' && lock_state == 0) {
      lock_state++;
   else if (rxd == 'a' && lock_state == 1) {
      lock_state++;
   else if (rxd == 'v' && lock_state == 2) {
      lock_state++;
   else if (rxd == 'e' && lock_state == 3) {
      lock_state++;
   else if (rxd == ' ' && lock_state == 4) { // got the entire string "Dave ", in that order
      lock_state = 0; // reset our "combination lock"
      got_id = TRUE;
      valid_data_count = 0xff; // get ready to count the number of data bytes - we know we have to expect 5 (Rocks)
      // also going to reset the buffer write index back to 0, so that I know where my valid data will be
      rx_wr_index = 0;
   else { // we didn't receive "Dave ", so reset the lock back to the beginning
      lock_state = 0;
   if (got_id && ++valid_data_count == 5) {
      data_avail = TRUE;
      got_id = FALSE;
#int_TBE
void TBE_isr(void) {
   if (tx_counter != 0) {
      putc(tx_buffer[tx_rd_index]);
      if (++tx_rd_index > TX_BUFFER_SIZE) {
         tx_rd_index = 0;
      tx_counter--;
      if (tx_counter == 0) {
         disable_interrupts(INT_TBE);
void bputc(int c) {
   int restart = 0;
   while (tx_counter > (TX_BUFFER_SIZE - 1));
      restart = 1;
   tx_buffer[tx_wr_index++] = c;
   if (tx_wr_index > TX_BUFFER_SIZE) {
      tx_wr_index = 0;
   tx_counter++;
   if (restart == 1) {
      enable_interrupts(INT_TBE);
      SETUP_ADC(ADC_OFF);
setup_spi(FALSE);
setup_oscillator(OSC_4MHZ);
   //enable_interrupts(INT_TBE);
   enable_interrupts(global);
   while (TRUE) {
      restart_wdt();
      if (data_avail) {
         data_avail = FALSE;
TX
#include <16F88.h>
#include <STRING.H>
#include <STDIO.H>
#include <STDLIB.H>
// DEFINES
// COMPILER DIRECTIVES and HARDWARE CONFIGURATION
#use delay(clock = Fosc)
   SETUP_ADC(ADC_OFF);
output_low(PIN_A1);
//output_low(PIN_B5);
setup_spi(FALSE);
      output_toggle(PIN_A1);
      fprintf(Wireless, "%c", 0xBA); // LAM - something for the RX's USART to "lock onto"
      fprintf(Wireless, "%c", 0xBE); // LAM - something for the RX's USART to "lock onto"
      fprintf(Wireless, "%c", 0xFA); // LAM - something for the RX's USART to "lock onto"
      fprintf(Wireless, "%c", 0xCE); // LAM - something for the RX's USART to "lock onto"
      fprintf(Wireless,"Dave Nice\r"); // I'm going to get the RX code to look for "Dave " as the ID...
      // ...and "Rocks" as the command/data
It's like as i power up receiver it goes enter immediately in INT_RDA and never get out of it.
I put HIGH PIN_A2 in INT RDA and in while true I also put some code but as i power up device it set high PIN A2 and doesn't execute code in while(true).
can you help me??
rnielsen
PostPosted: Wed Jun 21, 2006 9:57 am     Reply with quote
So, help me here. Have you been able to communicate between PIC's with this code? If not, I would try to establish communications between the PIC's directly first and prove that your code works before you start to enter outside problems. Once the code will allow the two PIC's to talk to each other, when hard-wired together, then try to put the wireless components into the circuit. A scope would be of tremendous help to ensure that you have an RF output, too. I've never tried to use one of those modules so I'm not sure how to get them going. I like to take the easy route and used a wireless module from www.maxstream.net called the XBEE. It's very compact and works quite well.
Good luck!
Ronald
newguy
PostPosted: Wed Jun 21, 2006 10:13 am     Reply with quote
Ditto what Ronald said. Directly connect TX pic and RX pic - no RF modules between them. Get them talking first, then insert the RF tx & rx.
One thing I did notice, though - are you using the pic's internal oscillator (INT_RC fuse is set)? Be careful with the internal oscillator - it's not very stable. You may have troubles matching baud rates between TX and RX.
fuzzy
PostPosted: Wed Jun 21, 2006 10:45 am     Reply with quote
Finally i got it!!
i don't know if it's only my fault or compiler fault too.
I added an instruction to force rs232 rx as INPUT as variable=input(PIN_B2); in main() and after it the code worked perfectly.
in my first code i set tris as input but i hadn't results so in homfray's code i didn't do it as he did.
what do you think about it??
