jc71229
| PLL and 18f252 |
Posted: Tue Jun 20, 2006 4:23 am |
Hi folks,
I want to use the H4 fuse to enable PLL. My 18f252 gets an external clock of 6MHz on OSC1/CLKIN (same as http://www.ccsinfo.com/forum/viewtopic.php?t=27349&highlight=pll). However I can't get it into PLL mode (delays are 4 times slower as expected). Is this even possible with an external clock? I use
#fuses H4, NOWDT, NOPROTECT, PUT, NOBROWNOUT, NOLVP
for my fuse setting. I didn't notice that I have to do additional adjustments. My compiler is: CCS PCH C Compiler, Version 3.204, 24828 (Linux Version)
Anyone who can help?
Jens |
Posted: Tue Jun 20, 2006 5:24 am |
It should work.
However there can be problems with the PLL, locking onto the fundamental, instead of running at *4, if the input signal is larger than expected (remember it expects to see the sinusoid from a crystal output, rather than a logic level 'square wave'). Double check that your programmer is setting the H4 fuse, and try with a series resistor 'in line' (perhaps 300R), or a series capacitor. I have used this with no trouble, at 4MHz, with a 220pF in series.
asmallri
Joined: 12 Aug 2004 Posts: 1675 Location: Perth, Australia
Posted: Tue Jun 20, 2006 5:42 am |
Did you remember to power cycle the PIC after you programmed it the first time you set the H4 fuse? _________________ Regards, Andrew
jc71229
Posted: Tue Jun 20, 2006 6:39 am |
Yep, that was it! Didn't know that I have to do a power cycle. Thanks so much asmallri + Ttelmah
Have fun
Jens |
