Timer Overflow?
No_Fear
Timer Overflow?
PostPosted: Sat Jul 19, 2003 12:37 pm     Reply with quote
I would like to flash my led every 200 ms (It must be in high accuracy).Sometime ago Neutone gave me a code about overflowing timer0 but i even dont have any idea about how it works??? I also dont have any document how i can use it. It is something like that :
#bit Timer1_Interupt_Flag = 0x0C.0
while(!Timer1_Interupt_Flag );
Timer1_Interupt_Flag =0;
set_timer1(15508);
I even dont understand a line of this code.Help Please!
___________________________
Original Post ID: 144516180
John Taylor
Re: Timer Overflow?
PostPosted: Sat Jul 19, 2003 1:35 pm     Reply with quote
If your clock is 4mhz and the timer1 prescaler is 4, timer1 will increment every 4us. That means you have to count 50,000
timer1 increments to get 200ms. One way to do it is to set timer 1 to zero and then sit there and compare the timer value to 50,000 until it hits, then reset to zero and start over. This is a messy way to do it. The way that is shown below sets the initial value at (65536-50000)=15536 and then simply waits for a timer overflow that is generated in hardware. The advantage of this is there is a lot less coding to do, plus the overflow will generate an interrupt that can be dealt with in the background. Note that the example shows 15508 vs the 15536 above. You have to count for the time it takes to deal with the overflow or else you cycle will be greater than the 200ms target. Note that if you do not initially set the timer to the preload value, your very first cycle will be greater than you expect (~25\%)
//assign variable to bit which indicates timer overflow,
//adjust for your actual processors' sfr
//wait for timer to overflow
//when it does, clear the overflow flag
//set the timer such that (65536-15508) timer counts = 200ms
set_timer1(15508);
Original Post ID: 144516182
No_Fear
Re: Timer Overflow?
PostPosted: Sun Jul 20, 2003 12:00 pm     Reply with quote
Thanks for your reply.
So if i want something happen in every 200 ms i should write a code like :
while (1){
set_timer1(15508);
flash_led(); // a private procedure
Is that true?
:=If your clock is 4mhz and the timer1 prescaler is 4, timer1 will increment every 4us. That means you have to count 50,000
:=timer1 increments to get 200ms. One way to do it is to set timer 1 to zero and then sit there and compare the timer value to 50,000 until it hits, then reset to zero and start over. This is a messy way to do it. The way that is shown below sets the initial value at (65536-50000)=15536 and then simply waits for a timer overflow that is generated in hardware. The advantage of this is there is a lot less coding to do, plus the overflow will generate an interrupt that can be dealt with in the background. Note that the example shows 15508 vs the 15536 above. You have to count for the time it takes to deal with the overflow or else you cycle will be greater than the 200ms target. Note that if you do not initially set the timer to the preload value, your very first cycle will be greater than you expect (~25\%)
:=//assign variable to bit which indicates timer overflow,
:=//adjust for your actual processors' sfr
:=#bit Timer1_Interupt_Flag = 0x0C.0
:=//wait for timer to overflow
:=while(!Timer1_Interupt_Flag );
:=//when it does, clear the overflow flag
:=Timer1_Interupt_Flag =0;
:=//set the timer such that (65536-15508) timer counts = 200ms
:=set_timer1(15508);
Original Post ID: 144516198
No_Fear
Re: Timer Overflow?
PostPosted: Sun Jul 20, 2003 12:04 pm     Reply with quote
while (1){
set_timer1(15508);
Is that true?
Original Post ID: 144516199
Neutone
Re: Timer Overflow?
PostPosted: Mon Jul 21, 2003 8:45 am     Reply with quote
:=Hi,
:=I would like to flash my led every 200 ms (It must be in high accuracy).Sometime ago Neutone gave me a code about overflowing timer0 but i even dont have any idea about how it works??? I also dont have any document how i can use it. It is something like that :
:=I even dont understand a line of this code.Help Please!
The timer is really a counter that increments with the crystle ossolations. When the timer goes from binary 1111 1111 1111 1111 to 0000 0000 0000 0000 it has overflowed. When this happens the timer interupt flag is set to 1. As long as the flag is not 1 the timer has not overflowed. The while loop waits for the timer to overflow before allowing the code to continue. It takes an amount of time to count from 0000 0000 0000 0000 to 1111 1111 1111 1111 and this is the timers period. When you preload the timer you are shorting the timers period.
Original Post ID: 144516225
