PORTB direction problem!!
johnq
PostPosted: Fri Jul 18, 2003 12:16 am     Reply with quote
I have a silly problem with CCS picc compiler. When I send to the port b, 0xFF, portb bit 4 doesnt turn to logical 1. Would you help me please..My sample code is below.
Note: Eight LEDs are connected portb. All of LEDs are lighted except bit4 later the code below.
#if defined(__PCM__)
#include <16f877.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=16000000)
#use standard_io(B)
output_b(0xFF);
___________________________
Original Post ID: 144516126
Kenny
Re: PORTB direction problem!!
PostPosted: Fri Jul 18, 2003 1:19 am     Reply with quote
:=I have a silly problem with CCS picc compiler. When I send to the port b, 0xFF, portb bit 4 doesnt turn to logical 1. Would you help me please..My sample code is below.
:=Note: Eight LEDs are connected portb. All of LEDs are lighted except bit4 later the code below.
:=#if defined(__PCM__)
:=#include <16f877.h>
:=#fuses HS,NOWDT,NOPROTECT
:=#use delay(clock=16000000)
:=#use standard_io(B)
:=#endif
:=void main(void)
:=output_b(0xFF);
:=while(1);
Perhaps you mean the 4th led, bit 3?
If so, change line to
Regards
Kenny
Original Post ID: 144516129
Neutone
PostPosted: Fri Jul 18, 2003 9:54 am     Reply with quote
<font face="Courier New" size=-1>:=I have a silly problem with CCS picc compiler. When I send to the port b, 0xFF, portb bit 4 doesnt turn to logical 1. Would you help me please..My sample code is below.
:=#endif
:=void main(void)
:=output_b(0xFF);
:=while(1);
That pin is not able to output high. Only float and output low. Try wiring the LED's to +5 instead of ground. Then you pull the pins low to turn them on.</font>
Original Post ID: 144516149
Kenny
PostPosted: Sat Jul 19, 2003 4:26 pm     Reply with quote
:=#endif
:=void main(void)
:=output_b(0xFF);
:=while(1);
Did you mean port a? Bit 4 of port a is the one that needs the pullup.
Original Post ID: 144516186
johnq
PostPosted: Mon Jul 21, 2003 1:30 am     Reply with quote
:=:=I have a silly problem with CCS picc compiler. When I send to the port b, 0xFF, portb bit 4 doesnt turn to logical 1. Would you help me please..My sample code is below.
:=:=Note: Eight LEDs are connected portb. All of LEDs are lighted except bit4 later the code below.
:=:=#if defined(__PCM__)
:=:=#include <16f877.h>
:=:=#fuses HS,NOWDT,NOPROTECT
:=:=#use delay(clock=16000000)
:=:=#use standard_io(B)
:=:=#endif
:=:=void main(void)
:=:=output_b(0xFF);
:=:=while(1);
:=Did you mean port a? Bit 4 of port a is the one that needs the pullup.
No I mean the PORTB and I solved my problem with your help. Thank you...See you..
Original Post ID: 144516215
