Clockspeed and Baudrate
Tagge
PostPosted: Tue Jun 13, 2006 8:26 am     Reply with quote
If I try to set a crystal >4Mhz I get an error in my
#use rs232(baud=300, xmit=PIN_C6, rcv=PIN_C7, bits=7, parity=E, ERRORS, RESTART_WDT)
Baudrate out of range!
I tryed for example a 20MHz, that should according to microchip data give 0.3Kbaud.
But only if Sync=0, BRGH=0 and BRG16=1.
How do I change this parameters (write the bits) thrue CCS inbuilt functions?
By the way, Im using a PIC18F2525.
Mark
PostPosted: Tue Jun 13, 2006 10:10 am     Reply with quote
Did you try adding BRGH1OK? I didn't see anything for BRG16 so maybe its tied to that parameter. Another option would be to set it up for another baud rate and then set the SPBRG and SPBRGH registers yourself.
Tagge
PostPosted: Tue Jun 13, 2006 10:59 am     Reply with quote
It doesnt seems to help at all.
It seems that the CCS functions dont support this baudrate with this crystal?
Im changing from a 4Mhz crystal to some faster one.
I also use the rs232 settings in different places in my code and I wouldnt want to make any major changes.
If I write the bits manually in the registers then the
#use rs232(300baud..) dont work anywere or?
newguy
PostPosted: Tue Jun 13, 2006 11:11 am     Reply with quote
I think what Mark was getting at was something like this:
- put a "bogus" baud rate in your #use rs232() line - something like 9600 which will work for your PIC and crystal.
- in your program, alter the SPBRG and SPBRGH registers yourself to values that should give you the necessary 300 baud.
If you do it this way, the compiler will be happy and you'll probably be able to get the baud rate you want.
Mark
PostPosted: Tue Jun 13, 2006 11:46 am     Reply with quote
Correct Smile
