Anybody having problems/success programming/debuging 16F689
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
dennisb
PostPosted: Mon Jun 12, 2006 10:38 pm     Reply with quote
Howdy,
I noticed that this part is listed as 'beta' for programming and needs an adapter for debugging.
I have the Microchip 'adapter' and it dosen't seem to work at all, with the ICD-U40 and programs correctly 1 out of 5 times.
Verify shows patterns like
--- Actual 2000 Expected 3000
--- Actual 0000 Expected 00C8
Seems to program OK when the chip is cold. Then when you reprogram it (within 5 minutes) you get the errors. Leave it alone for an hour and it will program OK, followed by failures.
Tied 3 or 4 chips, same results. 5 volts is rock solid.
Anybody seen similar results ??? Thanks
DennisB
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
