SuMa
| external interrupt as an input source |
Posted: Sun Jun 11, 2006 1:50 pm |
Hi, I am trying to measure a pusewidth with an interrupts service because I need it.
I am displaying an led`s display and when the interrupt arrives the PIC refesh the display with the new value.
All the information cames by a serial wire direct to the B0 pin, the external interrupt pin. Can I use this pin also as an input pin, to measure the pusewidth of the serial information?
The code is something like this... I am working with this an it doesnt work.
I dont know if it's possible to use the PIN B0(external interrupt) as an input pin inside of the interrupt routine.
#int_EXT
EXT_isr() {
x=input(PIN_B0);
for (i=0;i<50;i++)
if (x==1) pulsewidth++;
void main() {
enable_interrupts(INT_EXT);
enable_interrupts(global);
etc...
Thanks... |
Posted: Sun Jun 11, 2006 4:04 pm |
Yes, you can read the pin in the interrupt.
What you show, will not as far as I can see, have any relationship to the input pulse width, since you read the input just once at the start of the interrupt, and then increment (or not) the pulsewidth value fifty times, based on this single reading...
SuMa
Posted: Mon Jun 12, 2006 12:52 am |
Thanks Ttelmah
The correct code will be something like this:
#int_EXT //external interrupt on PIN B0
EXT_isr() {
for (i=0;i<50;i++) //cheking the pulsewidth of the serial data on B0
x=input(PIN_B0);
void main() {
etc...
I am trying to make it works but I dont get it, I dont know why... |
Posted: Mon Jun 12, 2006 2:26 am |
It is important perhaps to understand the timings involved.
It takes about 30 instruction times (depends on the PIC), to actually arrive in the handler. Then your 'loop', will take perhaps 10 instruction times, and another couple if the signal if high. So the 'effect', will be to ignore the first perhaps 35 instruction times of the pulse width, and then during the next 500 instruction times, if it is high at any point when tested, pulsewidth will increment, otherwise it will stay the same.
So, repeated pulses will still give the same increment of the count, and the first few uSec (depending on your clock rate), will be ignored.
I'd perhaps suggest:
#int_EXT
void EXT_isr(void) {
int i=0; //you do not show the declaration of this. Try to keep things
//That are only used locally, 'local', not global.
//PulseWidth, is presumably a 'global' variable. It needs to be zeroed,
//Or it'll just get larger every time.
pulsewidth=0;
while (input(PIN_B0) {
pulsewidth++;
if (++i==50) break;
This will still ignore the first few uSec, since this is an unavoidable implication of using interrupts. If you want accurate timing in this part of the pulse, external hardware will be needed.
However, this stops counting, as soon as the pulse drops, or when a maximum of 50 counts have occurred. Note that you don't need to add a seperate variable, and then test this, to test the pin.
SuMa
Posted: Mon Jun 12, 2006 7:56 am |
| Thanks Ttelmah, I will try it this evening... |
