ext_int_edge in an ISR?
ajt
PostPosted: Fri Jul 18, 2003 4:59 pm     Reply with quote
Is there any reason to not call ext_int_edge in an ISR? I want to do this to do x2 decoding of an encoder and want the interrupt to fire on both edges of the Phase A pulse.
Al
___________________________
Original Post ID: 144516165
Al Testani
Re: ext_int_edge in an ISR?
PostPosted: Fri Jul 18, 2003 5:39 pm     Reply with quote
:=Is there any reason to not call ext_int_edge in an ISR? I want to do this to do x2 decoding of an encoder and want the interrupt to fire on both edges of the Phase A pulse.
<a href="http://groups.google.com/groups?threadm=003101c2be31\%246e003ee0\%240300a8c0\%40main" TARGET="_blank">http://groups.google.com/groups?threadm=003101c2be31\%246e003ee0\%240300a8c0\%40main</a>
Original Post ID: 144516166
John Taylor
PostPosted: Sat Jul 19, 2003 1:44 pm     Reply with quote
I did what you're suggesting to time 4 channels of RC PPM control with the 4 port B interrupt on a PIC18F6620 and out of an hour of testing did not miss a single edge (4 independent pulses with a 15ms average period of continuously variable duty cycle). The only requirement is that your ISR (+context switching) can't make you miss any edge.
Original Post ID: 144516183
