eeprom to byte
Levett Prins
eeprom to byte
PostPosted: Fri Jul 11, 2003 2:35 am     Reply with quote
I have a Ds2438 ROM address stored on eeprom in the hex form e.g. 26D1B0330000001D. I must now pass the address to the touch_write_byte function in bytes. Can anyone advise? I have tried a few this including the following, but without success!
void Match_ROM()
int EEPRi;
char ID[4];
touch_present();
touch_write_byte(0x55); //match ROM
ID[0]='0'; ID[1]='x';
for (EEPRi=135; EEPRi<151; EEPRi=EEPRi+2)
ID[2]=read_eeprom(i);
ID[3]=read_eeprom(i+1);
touch_write_byte(ID); // Write ROM address
___________________________
Original Post ID: 144515867
R.J.Hamlett
Re: eeprom to byte
PostPosted: Fri Jul 11, 2003 4:21 am     Reply with quote
:=I have a Ds2438 ROM address stored on eeprom in the hex form e.g. 26D1B0330000001D. I must now pass the address to the touch_write_byte function in bytes. Can anyone advise? I have tried a few this including the following, but without success!
:=void Match_ROM()
:=int EEPRi;
:=char ID[4];
:=touch_present();
:=touch_write_byte(0x55); //match ROM
:=ID[0]='0'; ID[1]='x';
:=for (EEPRi=135; EEPRi<151; EEPRi=EEPRi+2)
:= ID[2]=read_eeprom(i);
:= ID[3]=read_eeprom(i+1);
:= touch_write_byte(ID); // Write ROM address
I would assume, you actually need to convert from hex, to the raw value, which you are not doing. Something like:
#define intval(x) ((x)<':')?((x)-'0'):((x)-'7')
void Match_ROM()
int EEPRi;
char ID;
touch_present();
/* I am not sure why you are setting up extra bytes here?. My memory of the '1 wire' interface, is that after the '55' header byte, it looks immediately for the 64bit address?. If so, it is the address bytes that are now needed. */
//Put the first hex value as the MS nibble
ID=intval(read_eeprom(i))<<4;
//Add the second, as the LS nibble
ID=ID+intval(read_eeprom(i+1));
/* At this point, the two hex digits, have been
assembled to a single byte (not two bytes as you show). */
This is based on some accesses I did to another 'one wire' device, so may not be right, but I think is probably closer to the right answer. :-)
Original Post ID: 144515868
Levett Prins
Re: eeprom to byte
PostPosted: Fri Jul 11, 2003 6:11 am     Reply with quote
Thanx, I am trying your advise but I get compiler error:
"Error[60] C:\PROGRA~1\PICC\PROJECTS\BMS\mach_rom.c 19 : Expecting :"
at function:
ID=intval(read_eeprom(EEPRi))<<4;
Can you perhaps see the problem?
Thank you
Levett
Original Post ID: 144515869
R.J.Hamlett
Re: eeprom to byte
PostPosted: Fri Jul 11, 2003 7:31 am     Reply with quote
:=Thanx, I am trying your advise but I get compiler error:
:="Error[60] C:\PROGRA~1\PICC\PROJECTS\BMS\mach_rom.c 19 : Expecting :"
:=at function:
:=ID=intval(read_eeprom(EEPRi))<<4;
:=Can you perhaps see the problem?
:=Thank you
I presume you did actually get a 'colon' on the #define line?. For some reason, the board turned the character in the #define line into a 'smiley' (I presume the keysequence used of close bracket colon open bracket, happens to match a value the board remaps into this character...). If not, then this is the cause of the error. Also, I think I'd actually do the input, and the translation on two lines, as:
int8 temp;
temp=read_eeprom(EEPRi);
ID=intval(temp);
Though the compiler ought to 'hold' the value, and not recall the function, I wouldn't want to rely on this, so using a temproary value avoids this worry.
Original Post ID: 144515871
Levett Prins
Re: eeprom to byte
PostPosted: Fri Jul 11, 2003 11:26 am     Reply with quote
Still no joy!!!
The code now look like this, but I still get the same error.
void Match_ROM()
#define intval(x) ((x)<':')?((x)-'0')):((x)-'7')
int8 EEPRi, EEPR_value;
char ID;
touch_present();
touch_write_byte(0x26); // Write FAMILY CODE for ds2438
EEPR_value=read_eeprom(EEPRi);
ID=intval(EEPR_value)<<4; //Put the first hex value as the MS nibble
EEPR_value=read_eeprom(EEPRi+1);
ID=ID+intval(EEPR_value); //Add the second, as the LS nibble
Thank you
Levett
Original Post ID: 144515884
R.J.Hamlett
Re: eeprom to byte
PostPosted: Fri Jul 11, 2003 1:30 pm     Reply with quote
:=Still no joy!!!
:=The code now look like this, but I still get the same error.
:=void Match_ROM()
:=#define intval(x) ((x)<':')?((x)-'0')) :=
It is the 'face' in the above line, that I was referring to. This is meant to be a ':', and has to be for the code to work. Annoyingly, if you just 'cut' the code and paste it, the face gets removed, but the colon gets lost. However I went the other way, and the board turned the colon, into the face!...
:=int8 EEPRi, EEPR_value;
:=char ID;
:=touch_present();
:=touch_write_byte(0x26); // Write FAMILY CODE for ds2438
:= EEPR_value=read_eeprom(EEPRi);
:= ID=intval(EEPR_value)<<4; //Put the first hex value as the MS nibble
:= EEPR_value=read_eeprom(EEPRi+1);
:= ID=ID+intval(EEPR_value); //Add the second, as the LS nibble
:=Thank you
:=Levett
Original Post ID: 144515885
Levett Prins
Re: eeprom to byte
PostPosted: Sat Jul 12, 2003 4:41 am     Reply with quote
I THINK I AM ALMOST THERE!
I understood you correctly regarding the "smiley". It appears the it represents ":(" and not only ":". So that's fixed now,
but I do not get the correct conversion.
E.g. for EEPROM values D & 1 (that represents the HEX value D1),
I correctly get ID=D0 with function: ID=intval(EEPR_value)<<4;
But with function ID=ID+intval(EEPR_value); , I then get ID=01.
It looks like the first value has been overwritten. To debug, I used: fprintf(PC, "ID=\%X", ID); to get the ID value.
Any suggestions?
Thanx
Levett
Original Post ID: 144515905
R.J.Hamlett
Re: eeprom to byte
PostPosted: Sun Jul 13, 2003 2:43 am     Reply with quote
:=I THINK I AM ALMOST THERE!
:=I understood you correctly regarding the "smiley". It appears the it represents "<img src="http://www.ccsinfo.com/pix/forum/sad.gif" border="0">" and not only ":". So that's fixed now,
:=but I do not get the correct conversion.
:=E.g. for EEPROM values D & 1 (that represents the HEX value D1),
:=I correctly get ID=D0 with function: ID=intval(EEPR_value)<<4;
:=But with function ID=ID+intval(EEPR_value); , I then get ID=01.
:=It looks like the first value has been overwritten. To debug, I used: fprintf(PC, "ID=\%X", ID); to get the ID value.
:=Any suggestions?
:=Thanx
:=Levett
Uurgh!.
There is no real reason hy the value should 'overwrite' like this, but you can try a couple of other ways of writing the same line, which might make the compiler get it right.
ID+=intval(EEPR_value);
//should be the same, but the use of the automatic addition
//may prevent the behaviour.
ID!=intval(EEPR_VAL);
In the latter case 'or-ing' the value, should remove any risk of the overwrite.
Original Post ID: 144515919
Levett Prins
Re: eeprom to byte
PostPosted: Sun Jul 13, 2003 2:30 pm     Reply with quote
The != did not work at all. The += worked only with e.g. 0xD1 but with 0x33 it generated 0x06 (adding 3+3). I eventually got it working with the following (non-elegant) code:
void Match_ROM()
int8 EEPRi, i, EEPR_value;
char ID;
touch_present();
for (EEPRi=137; EEPRi<151; EEPRi=EEPRi+2)
ID=0X00;
EEPR_value=intval(read_eeprom(EEPRi+1));
for (i = 0; i < 4; i++) if(bit_test(EEPR_value,i)) bit_set(ID,i);
EEPR_value=intval(read_eeprom(EEPRi));
for (i = 0; i < 4; i++) if(bit_test(EEPR_value,i)) bit_set(ID,(i+4));
Thank you very much for your advise and patience.
Regards
Levett
Original Post ID: 144515927
R.J.Hamlett
Re: eeprom to byte
PostPosted: Mon Jul 14, 2003 6:02 am     Reply with quote
:=The != did not work at all. The += worked only with e.g. 0xD1 but with 0x33 it generated 0x06 (adding 3+3). I eventually got it working with the following (non-elegant) code:
The html on the board, my keyboard/web browser, and what I am typing, are enjoying themselves... The character with the equals sign, should be the vertical pipe character, but is being shown as the exclamation mark... The pipe character, should result in the values being "or'ed", which should be a safe way of combining the values.
:=void Match_ROM()
:=#define intval(x) ((x)<':')?((x)-'0') :=
:=int8 EEPRi, i, EEPR_value;
:=char ID;
:=touch_present();
:=for (EEPRi=137; EEPRi<151; EEPRi=EEPRi+2)
:= ID=0X00;
:= EEPR_value=intval(read_eeprom(EEPRi+1));
:= for (i = 0; i < 4; i++) if(bit_test(EEPR_value,i)) bit_set(ID,i);
:= EEPR_value=intval(read_eeprom(EEPRi));
:= for (i = 0; i < 4; i++) if(bit_test(EEPR_value,i)) bit_set(ID,(i+4));
:=Thank you very much for your advise and patience.
:=Regards
:=Levett
The code behaviour, _should_ be fixable by bracketting. I deliberately ensured the function was fully bracketted in the define, but the compiler is behaving as if it treating the precedence differently from my expectations.
Your test loop approach, is a bit 'brute force', and will give the wrong result for any hex character above 9...
For instance, 'D1', will actually result in '41' being put into the output.
Do it like this instead, and avoid the 'inline' appoach I was using:
int intval(int val) {
if ((val)<':') return (val-'0');
return (val-'7');
void Match_ROM()
char ID;
touch_present();
ID=intval(read_eeprom(EEPRi));
ID = ID + (intval(read_eeprom(EEPRi+1) * 16)
You are showing some very 'odd' behaviours by the compiler. Is it perhaps a fairly old version?.
Original Post ID: 144515945
Levett Prins
Re: eeprom to byte
PostPosted: Sat Jul 19, 2003 1:24 am     Reply with quote
Thank you, it is working fine.
I am using PCM ver 3.163, so this could not have been the prolem with the previous approaches.
Regards
Levett
Original Post ID: 144516173
