Disabling Interrupts required ??
arunb
PostPosted: Fri Jul 18, 2003 7:05 am     Reply with quote
Hello All,
I am using the PIC 16F877 mcu, and the CCS PCM compiler.
I would like to know if it is necessary to call the disable_interrupts() function, before servicing an interrupt ?.
Also is it necessary to shut down all interrupt (by using the disable_interrupts() function) before writing to /reading the internal EEPROM using the write_eeprom() / read_eeprom() functions ??.
thanks
arun
___________________________
Original Post ID: 144516137
Sirio
Re: Disabling Interrupts required ??
PostPosted: Fri Jul 18, 2003 9:31 am     Reply with quote
:=Hello All,
Hi
:=I am using the PIC 16F877 mcu, and the CCS PCM compiler.
:=I would like to know if it is necessary to call the disable_interrupts() function, before servicing an interrupt ?.
No.
:=Also is it necessary to shut down all interrupt (by using the disable_interrupts() function) before writing to /reading the internal EEPROM using the write_eeprom() / read_eeprom() functions ??.
Don't think so.
:=thanks
np
:=arun
Original Post ID: 144516148
Felix Althaus
PostPosted: Fri Jul 18, 2003 12:17 pm     Reply with quote
Hi
From the PIC16F84A datasheet (but this is similar on the 16F87x):
"When an interrupt is responded to, the GIE bit is cleared to disable any further interrupt, [...]"
So, the PIC disables all interrupts for you. After the ISR, the chip turns the interrupts on again (exactly: the chip re-sets the GIE bit)
mfg
Felix
Original Post ID: 144516157
arunb
PostPosted: Fri Jul 18, 2003 9:44 pm     Reply with quote
:=:=Hello All,
:=Hi
:=:=I am using the PIC 16F877 mcu, and the CCS PCM compiler.
:=:=I would like to know if it is necessary to call the disable_interrupts() function, before servicing an interrupt ?.
:=No.
:=:=Also is it necessary to shut down all interrupt (by using the disable_interrupts() function) before writing to /reading the internal EEPROM using the write_eeprom() / read_eeprom() functions ??.
:=Don't think so.
:=:=thanks
:=np
:=:=arun
thanks for the reply.
I find that the mcu sometimes writes garbage to the EEPROM. I felt that disabling interrupts was required, because in the datasheets it is recommended to turn off all interrupts, does the isr routine for any isr does this automatically ???
thanks
arun
Original Post ID: 144516169
