Pass constant string to function
Levett Prins
PostPosted: Fri Jul 18, 2003 3:23 am     Reply with quote
I would like to pass a constant string to a function e.g.
TXT_EEPR(int EEPRStart, char * TXT)
int TXTi;
for(TXTi=0; TXTi }
void Main()
TXT_EEPR(100, "Text to write to EEPROM");
I get compiler error: "Bad expression syntax"
I managed to do it by first sprintf the constant string to an array, but this is too expensive on ROM.
Can someone please assist me to do this effectively.
Thank you
Levett
___________________________
Original Post ID: 144516133
R.J.Hamlett
Re: Pass constant string to function
PostPosted: Fri Jul 18, 2003 5:51 am     Reply with quote
:=I would like to pass a constant string to a function e.g.
:=TXT_EEPR(int EEPRStart, char * TXT)
:=int TXTi;
:=for(TXTi=0; TXTi :=}
:=void Main()
:=TXT_EEPR(100, "Text to write to EEPROM");
:=I get compiler error: "Bad expression syntax"
:=I managed to do it by first sprintf the constant string to an array, but this is too expensive on ROM.
:=Can someone please assist me to do this effectively.
:=Thank you
:=Levett
Basically, you can't.
The CCS compiler does not allow pointers to strings. However it does allow such strings to be addressed as arrays, or by a 'trick' shortcut.
int TXTi;
#define Reset_Ctr() TXTi=0;
TXT_EEPR(int EEPRStart, char TXT)
write_eeprom((EEPRStart+TXTi), TXT);
//Then if you want to start at '0' in the EEPROM, call:
Reset_Ctr();
This shortcut, calls the function once for each character in the message string, which will transfer the data as required. Since it does not though know when you have finished, you have to 'reset the counter' seperately.
Original Post ID: 144516134
