Ted Ems
| structures and pointers again |
Posted: Tue May 16, 2006 3:17 pm |
After looking at all the forum questions and answers i'm still a little unclear what goes where. The code below has an array of structures ( data_array) and a single structure ( temp_data ). The send_serial routine needs to be able receive either a structure of the array or the temp_data structure. What do i need to place in the function prototype and in the send_serial routine?
| Code: | #include "C:\CCS Projects\18f6620.h"
#opt 11
#zero_ram
#define Serial_RX_PIN PIN_G2
#define Serial_TX_PIN PIN_G1
#use rs232(baud=57600, xmit=Serial_TX_PIN, rcv=Serial_RX_PIN, errors, stream=Serial_Input,RESTART_WDT)
=====================What do i put in this function prototype?
void Send_Serial( ,int8 i); // send data out the serial port
struct data_packet
int error_code :5; // zero if no errors
// 1 if addr sent not equal to address rec
// 2 if current pulse greater then >30 ma( dup addr )
// 4 data not same as previous
// 8 incorrect parity
int leds :3;
int extra_flags :3;
int drift :1;
int sensitivity :4;
int interrupt :1;
int extended_protocol :1;
int alarm_flag :1;
int parity :1;
int input_command :4;
int8 address_trans;
int8 analog2;
int8 analog_value;
int8 device_type;
int8 address_rec;
int8 interrupt_alarm_address;
struct data_packet data_array[127] ;
struct data_packet temp_data;
int1 Service_serial(void){
struct data_packet *ptr;
int8 i;
int16 eeprom2_address,data_ptr;
int8 temp;
switch (buffered_data[1]){ // PACKET TYPE
case 16: // Normal type
switch (buffered_data[5]){ //COMMAND
case 01: // write data to eeprom
case 02: // read data from scan
if (buffered_data[2]==255){ // is it a broadcast
for(i=1;i<127;i++){
if (data_array[i].error_code==0){
Send_Serial(&data_array[i],i);
else{
case 03: // write data to eeprom from scan
active_node_counter=0;
eeprom2_address=0;
for(i=1;i<127;i++){
if ((int8)data_array[i].error_code==0)
active_node_counter++;
init_ext_eeprom();
write_ext_eeprom(0,active_node_counter); //save the number of active nodes
for(i=1;i<127;i++){
write_data_array_to_eeprom(&data_array[i],i);
write_ext_eeprom(eeprom2_address,data_array[nodeid].interrupt;
write_ext_eeprom(eeprom2_address,data_array[nodeid].extended_protocol;
write_ext_eeprom(eeprom2_address,data_array[nodeid].alarm_flag;
write_ext_eeprom(eeprom2_address,data_array[nodeid].parity;
write_ext_eeprom(eeprom2_address,data_array[nodeid].input_command;
write_ext_eeprom(eeprom2_address,data_array[nodeid].error_code;
write_ext_eeprom(eeprom2_address,data_array[nodeid].leds;
write_ext_eeprom(eeprom2_address,data_array[nodeid].address_trans;
write_ext_eeprom(eeprom2_address,data_array[nodeid].analog_value;
write_ext_eeprom(eeprom2_address,data_array[nodeid].analog2;
write_ext_eeprom(eeprom2_address,data_array[nodeid].drift;
write_ext_eeprom(eeprom2_address,data_array[nodeid].sensitivity;
write_ext_eeprom(eeprom2_address,data_array[nodeid].device_type;
write_ext_eeprom(eeprom2_address,data_array[nodeid].address_rec;
write_ext_eeprom(eeprom2_address,data_array[nodeid].interrupt_alarm_address;
case 04: // read data from eeprom
for(i=1;i<127;i++){
read_eeprom_to_temp_data(i);
Send_Serial(&temp_data,i);
else{
read_eeprom_to_temp_data(buffered_data[2]);
Send_Serial(&temp_data,buffered_data[2]);
case 255:
reset_cpu();
default:
default :
void read_eeprom_to_temp_data(int8 i){
int16 eeprom_address2;
int8 a[9];
int8 j;
eeprom_address2=1 + (i-1)*sizeof(temp_data);
for(j=0;j<sizeof(temp_data);j++){
a[j]=read_ext_eeprom(eeprom_address2);
eeprom_address2++;
memcpy(&temp_data,a,sizeof(temp_data));
void write_data_array_to_eeprom(int8 *tp,int8 i){
int8 *ptr;
int8 q,j;
ptr=tp;
q=*ptr++;
write_ext_eeprom(eeprom_address2,q);
eeprom_address2++;
================ What do i put in here?
void Send_Serial( ,i){
int8 temp,temp2;
fprintf(serial_input,"NODE# %u\r",i);
temp=0;
if (ptr->interrupt) // can't force a type conversion on int1 within a struct.
temp=1; // this sucks but it works
fprintf(serial_input,"Interrupt %u\r",temp);
temp=0;
if (ptr->extended_protocol)
temp=1;
fprintf(serial_input,"Extended protocol %u\r",temp);
temp=0;
if (ptr->drift)
temp=1;
fprintf(serial_input,"Drift %u\r",temp);
fprintf(serial_input,"Sensitivity %u\r",(int)ptr->sensitivity);
temp=0;
if (ptr->alarm_flag)
temp=1;
fprintf(serial_input,"Alarm flag %u\r",temp);
fprintf(serial_input,"Parity %u\r",(int)ptr->parity);
fprintf(serial_input,"Input command %u\r",(int)ptr->input_command);
fprintf(serial_input,"Error code %u\r",(int)ptr->error_code);
fprintf(serial_input,"Led state of last scan %u\r",(int)ptr->leds);
fprintf(serial_input,"Address trans %u\r",ptr->address_trans);
fprintf(serial_input,"Analog2 %u\r",ptr->analog2);
fprintf(serial_input,"Analog1 %u\r",ptr->analog_value);
fprintf(serial_input,"Device type %u\r",ptr->device_type);
fprintf(serial_input,"Address_rec %u\r",ptr->address_rec);
fprintf(serial_input,"Interrupt_alarm %u\n\r",ptr->interrupt_alarm_address);
Mark
Posted: Tue May 16, 2006 6:03 pm |
| struct data_packet *ptr |
Ted Ems
| pointers and structures |
Posted: Wed May 17, 2006 5:38 am |
Mark
The compiler returns with an error message saying "Function definition different from previous". Got any suggestions |
| Re: pointers and structures |
Posted: Wed May 17, 2006 6:20 am |
| Ted Ems wrote: | | The compiler returns with an error message saying "Function definition different from previous". Got any suggestions | This error means your function declaration (at the start of the program) is different from the implementation (your actual function). |
Mark
Posted: Wed May 17, 2006 6:31 am |
| You also need to declare the struct before your function prototype. |
Posted: Wed May 17, 2006 6:45 am |
Remember the structure type, must be declared, before the prototype function.
As an 'aside', there is no point in using an int1 return fom a function. The compiler always has to return at least a byte. The effect varies with compiler versions, but on some, using int1, actually results in slightly bulkier code, as the compiler evaluates the logic, converts it to a byte, then tests this again on the return. Like you, I felt it seemed logical to return a single bit for a flag, but I found on one particular program the result got larger. Inspecting the .LST, showed what was happening.
Ted Ems
Posted: Wed May 17, 2006 8:24 am |
I've looked at this code off and on for a couple days. Did not even occur to me that the declaration was in the wrong place.
Thanks for all the help |
