ICD2 Microchip
prfc
ICD2 Microchip
PostPosted: Fri Mar 31, 2006 6:45 am     Reply with quote
I have used CCS compiler to write my program and now I need an ICD to debug it. I have the ICD2 of Microchip.
Can I use my ICD2 of Microchip to do it or I have to get CCSs ICD?
gs
PostPosted: Fri Mar 31, 2006 12:27 pm     Reply with quote
Yes you can.
You must integrate CCS into MPLAB, and you can use your ICD2 normally.
You dont have to use the "#DEFINE ICD TRUE" (I dont remember the exact spelling) statement in your source code, but only the checkbox somewhere in the compiler options.
www.hlektronika.gr
prfc
PostPosted: Tue Apr 04, 2006 1:35 am     Reply with quote
My only connector to the PIC18 is a FCI Female Connector.
Datasheet:
FCI part number 91931-31121
Can I use ICD2 of Microchip through this connector?
Thanks.
rberek
PostPosted: Thu Apr 06, 2006 8:50 am     Reply with quote
I think you'll have to build your own cable, as the ICD2, if I remember, uses an RJ11 cable like the ICDU-40.
carmarmu
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sat May 13, 2006 1:08 pm     Reply with quote
You must use your own connector.
If you want a more cheap connector, put on your PCB a pin array male and do an adaptor for ICD2, RJ11 to pin array female...
I do it alwais, is more cheap Smile
Donīt forget put the statement:
#device ICD TRUE on your progam
Regards
Datasheet:
Thanks.
**CaRmArMu** Valencia (Spain)
