pcmguy
| pic power and frequency control! |
Posted: Fri Apr 28, 2006 8:02 pm |
Hi all, can anyone answer me:
1. What is the pic power consumtion and crystal speed relation? e.g. if same project i use pic16f84 with 4MHz and 20MHz, how much power will safe from using 4MHz? 1, 2, 4X?
2. If i use pic16f84A, what crystal speed can use? 4MHz? 20MHz? What's about if I use pic16f84-20IP? can I use 4MHz crystal?
3. If I want use switch input for my PIC, normally I use 10K ohm resistor to pullup, may I know what is the maximum ohm I can put? 4k7? 100k?
Thanks!
Yours PCM GUY, |
Mark
Posted: Fri Apr 28, 2006 8:42 pm |
| All of your questions can be answered by reading the datasheet. |
rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
Posted: Fri Apr 28, 2006 8:50 pm |
Also note that the top speed of the PIC16F84 is 10 MHz. There is no PIC16F84-20IP. There is a PIC16F84A-20I/P
The max frequency of a PIC is given on the first page of its datasheet.
r.b. |
