RS-232 TX Problem
Piet Fourie
RS-232 TX Problem
PostPosted: Mon Jul 14, 2003 11:21 am     Reply with quote
Hi
I just upgraded to the latest compiler available from CCS webpage.
The problem;
If I transmit a specific character over the RS-232 the pic (F877) crashes. Any other code transmitted is ok.
Example of Basic problem
a = 0x10 ;
putc(a) ; //No Problem the thing works
a = 0x05 ;
putc(a) ; //The program crashes.
I have removed all other code from the program which is very big and only have the RS-232 section working and everytime the code is 0x05 the pic crashes.
Hope somebody can help, I am very frustrated and the deadline is upon me.
Regards
Piet
___________________________
Original Post ID: 144515958
Neutone
Re: RS-232 TX Problem
PostPosted: Mon Jul 14, 2003 11:46 am     Reply with quote
:=Hi
:=I just upgraded to the latest compiler available from CCS webpage.
:=The problem;
:=If I transmit a specific character over the RS-232 the pic (F877) crashes. Any other code transmitted is ok.
:=Example of Basic problem
:=a = 0x10 ;
:=putc(a) ; //No Problem the thing works
:=a = 0x05 ;
:=putc(a) ; //The program crashes.
:=I have removed all other code from the program which is very big and only have the RS-232 section working and everytime the code is 0x05 the pic crashes.
:=Hope somebody can help, I am very frustrated and the deadline is upon me.
:=Regards
:=Piet
The biggest difference in those numbers is how many consecutive zero bits follow the start bit in the byte transmition. How accurate is your clock and baud rate?
Original Post ID: 144515959
Sherpa Doug
PostPosted: Mon Jul 14, 2003 12:00 pm     Reply with quote
:=The problem;
:=a = 0x10 ;
:=a = 0x05 ;
What do you mean by "crash"? Does the processor reset? Does the clock keep running? Does it crowbar the power supply?
Original Post ID: 144515960
John Taylor
PostPosted: Mon Jul 14, 2003 12:21 pm     Reply with quote
Chr 0x05 is an ENQ, is it possible that you are getting an immediate response from the other side of the RS232 connection that you don't expect? If you transmit with an interrupt handler, a new character into your input buffer could overrun your hardware receive buffer (Because you don't process it) and make all other reception impossible until the error is cleared.
//Check status of bit oerr once "Crashed" in 16F877:
#byte rcsta=0x18 //UART overrun error control variables
#bit cren=rcsta.4 //adjust addressing for processor
#bit oerr=rcsta.1
//If oerr is high, it can only be cleared by toggling cren...
//overrun error clearing, perform every system loop -
if (oerr) //if overrun is true
cren=false; //toggle rcsta, cren bit to clear
cren=true;
:=:=Hi
:=:=I just upgraded to the latest compiler available from CCS webpage.
:=:=The problem;
:=:=If I transmit a specific character over the RS-232 the pic (F877) crashes. Any other code transmitted is ok.
:=:=Example of Basic problem
:=:=a = 0x10 ;
:=:=putc(a) ; //No Problem the thing works
:=:=a = 0x05 ;
:=:=putc(a) ; //The program crashes.
:=:=I have removed all other code from the program which is very big and only have the RS-232 section working and everytime the code is 0x05 the pic crashes.
:=:=Hope somebody can help, I am very frustrated and the deadline is upon me.
:=:=Regards
:=:=Piet
:=The biggest difference in those numbers is how many consecutive zero bits follow the start bit in the byte transmition. How accurate is your clock and baud rate?
Original Post ID: 144515964
