PCW CCS: Return from assembly function ?
eng_amr
PostPosted: Sun Jul 13, 2003 4:11 pm     Reply with quote
I have a assembly function like that
void myfunc (void)
#asm
" // my assembly lines
return
return
#endasm
I want to know how can i return from the assembly function .
I tried the _return_ found it in the manual.
But it give me this error Undefined identifier _return_
And how can i return with a value in assembly function ?
___________________________
Original Post ID: 144515928
Re: PCW CCS: Return from assembly function ?
PostPosted: Sun Jul 13, 2003 4:49 pm     Reply with quote
:=I want to know how can i return from the assembly function .
:=And how can i return with a value in assembly function ?
How about this:
<PRE>
#include "c:\Program Files\Picc\Devices\16F877.H"
#use delay(clock = 8000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
<BR>
char test(char value);
<BR>
char c;
<BR>
c = test(0x20);
<BR>
<BR>
#asm
movlw 0x08 // This is the return code for this test.
btfsc value, 0 // Is bit 0 of value set ?
goto done // If so, return 0x08
<BR>
movlw 0x40 // This is the return code for this test.
btfsc value, 1 // Is bit 1 of value set ?
goto done // If so, return 0x40
<BR>
// etc.
<BR>
movlw 0x00 // Default return value
done:
movwf _return_ // Put the return value into _return_
#endasm
<BR>
</PRE>
Note: The tests, and the return codes are completely arbitrary
and are just shown to demonstrate the idea.
Original Post ID: 144515929
eng_amr
PostPosted: Mon Jul 14, 2003 5:38 am     Reply with quote
Thanks your code works fine but when i try to compile my code it state that error "Undefined identifier _return_ "
here is my code
#include <16F84.h>
#Case
#fuses XT,NOWDT,NOPROTECT,PUT
#use delay (clock=4000000)
#byte portb=0x06
#byte porta=0x05
unsigned char Cntr,P_Val;
int Pulsin(void);
int c;
// set_tris_b(0x00);
// set_tris_a(0xff);
c=Pulsin();
int Pulsin(void)
// pulse measurement subroutine
#asm
Clrwdt // Walk the dog
Clrf Cntr // Clear the variables used,
Clrf P_Val // prior to the subroutine
Trans: Btfss porta,2 // Wait for a 1 to 0 transition
Goto Edge // Edge found!
Incfsz P_Val // Else, increment P-VAL until >255
Goto Trans
Incfsz Cntr // Loop until 255
Goto Trans
goto done
Edge: Clrf P_Val // A 1 to 0 transition occurred
Edge_LP: Btfsc porta,2 // Count how long it's logic 0
goto done
Nop // Timing loop
Nop
Nop
Nop
Nop
Incfsz P_Val // Increment P_VAL until >255
Goto Edge_LP
done:
movf P_Val,w
movwf _return_
#endasm
:=:=I want to know how can i return from the assembly function .
:=:=And how can i return with a value in assembly function ?
:=How about this:
:=<PRE>
:=#include "c:\Program Files\Picc\Devices\16F877.H"
:=#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
:=#use delay(clock = 8000000)
:=#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
:=<BR>
:=char test(char value);
:=<BR>
:=void main()
:=char c;
:=<BR>
:=c = test(0x20);
:=<BR>
:=while(1);
:=<BR>
:=#asm
:=movlw 0x08 // This is the return code for this test.
:=btfsc value, 0 // Is bit 0 of value set ?
:=goto done // If so, return 0x08
:=<BR>
:=movlw 0x40 // This is the return code for this test.
:=btfsc value, 1 // Is bit 1 of value set ?
:=goto done // If so, return 0x40
:=<BR>
:=// etc.
:=<BR>
:=movlw 0x00 // Default return value
:=done:
:=movwf _return_ // Put the return value into _return_
:=#endasm
:=<BR>
:=</PRE>
:=Note: The tests, and the return codes are completely arbitrary
:=and are just shown to demonstrate the idea.
Original Post ID: 144515942
PostPosted: Mon Jul 14, 2003 12:07 pm     Reply with quote
<font face="Courier New" size=-1>:=
:=Thanks your code works fine but when i try to compile my code it state that error "Undefined identifier _return_ "
The problem is caused by using the #case statement, while
typing _return_ with lower case letters.
If you compile with the +LS option, you can see the symbol
table at the end of the MPLAB .LST file. The symbol table
spells it as: _RETURN_
So if you use #case, you must use upper case, like this:
movwf _RETURN_</font>
Original Post ID: 144515962
