Harry Mueller
| minus signs not showing up consistently in printf |
Posted: Fri Apr 21, 2006 6:39 am |
In a debugging exercise I print out 3 variables. The calculations are all done correctly but two of the printed values, Accel_percent and Avg may or may not show a minus sign, it seems almost arbitrary. The value Acceleration , a value between +10,000 and -10,000 always shows the proper sign.
Here are the three printf statements:
| Code: | printf("\r\nAcceleration = %ld", accel_value);
printf("\r\nAccel_percent = %4ld.%02ld", accel_value/100, accel_value%100);
printf("\r\nAvg= %4ld.%02ld",running_av_accel/100, running_av_accel%100); |
Any idea why this is happening and how it can be corrected?
Thanks, Harry |
Posted: Fri Apr 21, 2006 8:23 am |
What compiler version?.
There was a bug that applied to a few versions, where if the 'carry' flag is set from one arithmetic operation, it incorrectly gets displayed as a 'sign', in printf...
If you do the arithmetic 'outside' the printf, it doesn't happen. Also consider that if you have a reasonably recent compiler, you could use %w instead of doing the splitting yourself. Also, look at ldiv.
SherpaDoug
Posted: Fri Apr 21, 2006 8:25 am |
Can you show us the declarations for these variables and the math that calculates them? I suspect somewhere you are using an unsigned type to hold a signed value. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Harry Mueller
Posted: Fri Apr 21, 2006 9:40 am |
| Ttelmah wrote: | What compiler version?.
My compiler version is 3.245. I will try using %w to see if that clears it up, however I would really like to know what is causing my problem just to learn more.
What is ldiv?
Thanks, Harry |
Harry Mueller
Posted: Fri Apr 21, 2006 9:44 am |
| SherpaDoug wrote: | | Can you show us the declarations for these variables and the math that calculates them? I suspect somewhere you are using an unsigned type to hold a signed value. |
I don't think I've done that but maybe I've missed something. Here is all my code....hope it's not too long to go through. | Code: | //This program computes acceleration and rate of change with an accelerometer
// and a gyro and uses these values to calculate torque for the DC motors.
// It uses an interrupt on port_b for both calculations.
#include <16F877.H>
#include <24256-1.c>
#use delay(clock = 20000000)
#use RS232(BAUD=38400,XMIT=PIN_C6,RCV=PIN_C7)//communication link with BotLoader
//raise this value as high as you can without overflowing the math
#define ADXL202_SCALING_FACTOR 100000
#define motor_fwd 0b00000011
#define motor_rev 0b11111100
//global vars...................................................................
int current_portb, delta_portb, count;
signed int16 running_av_accel, gyro_value;
unsigned int16 accel_period, accel_pulse, reading, adxl_ppg;
unsigned int16 accel_value_address, gyro_pulse, last_gyro_pulse;
signed int32 adxl_zerog;
static int8 index = 0, flag = 0;
static int last_portb;
static unsigned int16 accel_old_reading, gyro_old_reading;
//Initialization routines.......................................................
void motor_init()
int8 torque;
int1 flag=0;
//port_b_pullups(TRUE); // ????
setup_timer_2(T2_DIV_BY_1,199, 1); // 25 KHz
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_ccp2(CCP_PWM); // Configure CCP2 as a PWM
void accelerometer_init(unsigned int32 zerog, long ppg)
adxl_zerog=zerog;
adxl_ppg=ppg;
setup_timer_0 (RTCC_INTERNAL | RTCC_DIV_32);
setup_timer_1 (T1_INTERNAL);
enable_interrupts(INT_RTCC);
enable_interrupts(INT_RB);
//Interrupts service routines...................................................
#int_RTCC // Output 1500 uS pulse
Gyro_input_isr()
set_timer0(22);
if (++count==12)
count = 0;
if(count<2)
output_high(PIN_E2);
output_low(PIN_E2);
#int_RB
void accel_gyro_isr(void)
reading = get_timer1(); //Read Timer_1
current_portb = input_b(); //Read value of PORT_B
delta_portb = (current_portb ^ last_portb) >> 4; //Did PORT_B change?
last_portb = current_portb; //Remember PORT_B value
if ((delta_portb == 0x08) ||
(delta_portb == 0x0c)) //If PIN_B7 has changed
if (bit_test(current_portb, 7)) //If PIN_B7 is high
accel_period = reading - accel_old_reading; //Calculate period
accel_old_reading = reading;
accel_pulse = reading - accel_old_reading; //Calculate duty
else if ((delta_portb == 0x02) ||
(delta_portb == 0x06) ||
(delta_portb == 0x0a) ||
(delta_portb == 0x0e) ||
(delta_portb == 0x0f))
if (bit_test(current_portb, 5)) //If PIN_B5 is high
gyro_old_reading = reading; // Record timer_1 reading
gyro_pulse = reading - gyro_old_reading; //Calculate gyro_pulse
//Functions.....................................................................
// A(g) = (T1/T2 - 0.456) / 0.118
// 0g = 50% duty cycle
signed int16 accelerometer_read(void)
signed int32 value;
value = accel_pulse * ADXL202_SCALING_FACTOR;
value = value / accel_period;
value = value - adxl_zerog;
value = (value * 10000) / adxl_ppg;
return(value);
signed int16 gyro_read(void)
signed int32 value;
value = (gyro_pulse / 5) - 1500; // Covert ticks to change in uS
return(value);
signed int16 running_average(signed int16 add_value)
static signed int16 vals[6], sum;
signed int16 result;
if ((index==0) && (flag == 0)) //discard phoney first value
add_value = 0;
if (flag==5) // continue once five values have been received
sum += add_value;
sum -= vals[index];
vals[index] = add_value;
result = sum / 5;
index = (index+1) % 5;
flag = 5;
return(result);
else //fill up the first 5 values and calculate sum
sum += add_value;
result = sum / ++index;
if (index==5)
index = 0;
flag++;
return(result);
motor_control()
int16 K_accel = 1, K_gyro = 1;
signed int16 torque = 0;
torque = ((running_av_accel/100) * K_accel) +
(gyro_value * K_gyro);
//printf("\n\rMotor_control section.............................");
//printf("\r\nrunning_av_accel = %ld ",running_av_accel/100);
//printf("\r\ngyro_value = %ld ",gyro_value);
//printf("\r\nTorque = %ld ",torque);
i2c_start();
i2c_write(0x40);
if ((torque > 50) || (torque < (-50)))
if (torque > 0)
i2c_write(0b00000011);
i2c_write(0b11111100);
i2c_stop();
set_pwm1_duty(4*abs(torque)); // calculated duty cycle on pin B2
set_pwm2_duty(4*abs(torque)); // calculated duty cycle on pin B1
else;
//Main program..................................................................
main()
accelerometer_init(45600,11750); //calibrated values
init_ext_eeprom(); // initialize external EEPROM
motor_init(); // initialize motors
while (1)
signed int16 accel_value;
accel_value = accelerometer_read();// "Value" varies from -10,000 to +10,000
//write_ext_eeprom(accel_value_address, accel_value);
running_av_accel = running_average(accel_value);
gyro_value = gyro_read();
motor_control();
printf("\n\rMain section.................................................");
printf("\r\nGyro rate of change = %ld%%",gyro_value);
printf("\r\nAvg Acelleration = %4ld.%02ld",running_av_accel/100, running_av_accel%100);
delay_ms(250);
Thanks, Harry |
Harry Mueller
Posted: Fri Apr 21, 2006 12:28 pm |
| Harry Mueller wrote: | | Ttelmah wrote: | What compiler version?.
What is ldiv?
Thanks, Harry |
I used the %W format and it cleared the problem up. Thanks, Ttelmah, I didn't even know that existed.
Harry |
Posted: Fri Apr 21, 2006 2:30 pm |
The 'sign bug', was posted about a few weeks ago, with another poster performing arithmetic inside the printf, and getting similar behaviour. If I remember at the time, somebody posted the assembler listing being generated for the arithmetic. If the arithmetic is done outside the printf (put into a variable), it doesn't happen.
Glad %w at least solved the 'effect'. :-)
