basic pic code
pdabir
basic pic code
PostPosted: Thu Apr 13, 2006 8:15 pm     Reply with quote
I'm writing basic pic code for a PIC16F88. All I want to do is for basic testing purposes just output a high for the digit for in (Pin_B0) by setting the user2 value to 1. For some reason, I cannot get this basic code to work, please help. Most of this code is commented out to test. All I want to do is the function settemp. When I compile and run this code, nothing lights up at all.
#include <16F88.h> // <-- This is the type of PIC you're using.
// Other supported PICs are in:
// C:\Program Files\PICC\Devices
//#device ICD=TRUE
#device *=16 ADC=10 // Use 16-bit pointers, use 10-bit ADC
#fuses HS // You may or may not want some of these ....
#fuses NOWDT
#fuses NOPROTECT
#fuses NOLVP
#fuses NODEBUG
#fuses NOPUT
#fuses NOBROWNOUT
// These require use of Set_Tris_x()
#use fast_io(A)
#use fast_io(B)
// End Preprocessor Directives
#include "Include\Compiler.h"
#include "Include\Globals.h"
* F U N C T I O N P R O T O T Y P E S *
// when you test, comment out all ADC stuff, comment out calculate temp
//void initADC(void);
void settemp(int8 user2, int8 user1, int8 user0);
//void calculatetemp(int actual2, int actual1, int actual0, int16 adcvalue);
//void checkpushbutton(int8 user2, int8 user1, int8 user0, int1 check);
//void inctemp(int8 user2, int8 user1, int8 user0);
//void dectemp(int8 user2, int8 user1, int8 user0);
void setdigit1(int8 user2);
void setdigit2(int8 user1);
void setdigit3(int8 user0);
//void comparetemp(int8 user2, int8 user1, int8 user0, int8 actual2, int8 actual1, int8 actual0);
* M A I N R O U T I N E *
#pragma zero_ram // Interesting command ....
int8 user2 = 1;
int8 user1 = 0;
int8 user0 = 0;
int8 actual2 = 0;
int8 actual1 = 9;
int8 actual0 = 9;
int1 check = true;
int16 adcvalue=0.0;
void main( void)
Backlight_Enabled = 0;
disable_interrupts(GLOBAL); // We don't want to be interrupted yet
output_low(Pin_A0);
output_low(Pin_A1);
output_low(Pin_A2);
output_low(Pin_A3);
output_low(Pin_A4);
output_low(Pin_A5);
output_low(Pin_A6);
output_low(Pin_A7);
output_low(Pin_B0);
output_low(Pin_B1);
output_low(Pin_B2);
output_low(Pin_B3);
output_low(Pin_B4);
output_low(Pin_B5);
output_low(Pin_B6);
output_low(Pin_B7);
delay_ms(50); // wait for voltages to stablize
Set_Tris_A(0b00111100); // Port A's I/O, 0b00010001
Set_Tris_B(0b00000000);
//output_low(Pin_B6); // should be output_low(Pin_B6)
settemp(user2, user1, user0);
//initADC();
while(forever)
// calculatetemp(actual2, actual1, actual0, adcvalue);
checkpushbutton (user2, user1, user0, check);
if(check==true)
setdigit1(actual2);
setdigit2(actual1);
setdigit3(actual0);
setdigit1(user2);
setdigit2(user1);
setdigit3(user0);
comparetemp(user2, user1, user0, actual2, actual1, actual0);
setdigit1(user2);
setdigit2(user1);
setdigit3(user0);
//setting up a to d converter
void initADC(void)
setup_adc_ports(sAN2); // A0 A1 Ref=A2,A3
set_adc_channel( 2 );
delay_us(10);
float temp=0.0;
adcvalue = read_adc();
temp= (adcvalue/1023);
temp=temp*3.5;
temp=temp*63.28-9.48;
adcvalue=temp/1;
while(adcvalue > 99)
actual2 += 1;
adcvalue-= 100;
while(adcvalue > 9)
actual1 += 1;
adcvalue -= 10;
while(adcvalue > 0)
actual0 += 1;
adcvalue -= 1;
if(input(Pin_A3)==1)
check=!check;
if(input(Pin_A4)==1)
inctemp(user2, user1, user0);
if(input(Pin_A5)==1)
dectemp(user2, user1, user0);
if(user0==9)
user0=0;
if(user1==9)
user1=0;
user2++;
else user1++;
else user0++;
if(user0==0)
user0=9;
if(user1==0)
user1=9;
user2--;
else user1--;
else user0--;
// Display digit 1
if(user2==0)
output_low(Pin_B0);
output_low(Pin_B1);
if(user2==1)
output_high(Pin_B0);
output_low(Pin_B1);
//Display Digit 2
if(user1==0)
output_low(Pin_B2);
output_low(Pin_B3);
output_low(Pin_B4);
output_low(Pin_B5);
if(user1==1)
output_high(Pin_B2);
output_low(Pin_B3);
output_low(Pin_B4);
output_low(Pin_B5);
if(user1==2)
output_low(Pin_B2);
output_high(Pin_B3);
output_low(Pin_B4);
output_low(Pin_B5);
if(user1==3)
output_low(Pin_B4);
output_low(Pin_B5);
if(user1==4)
output_low(Pin_B2);
output_low(Pin_B3);
output_high(Pin_B4);
output_low(Pin_B5);
if(user1==5)
output_low(Pin_B3);
output_low(Pin_B5);
if(user1==6)
output_low(Pin_B2);
output_low(Pin_B5);
if(user1==7)
output_low(Pin_B5);
if(user1==8)
output_low(Pin_B2);
output_low(Pin_B3);
output_low(Pin_B4);
output_high(Pin_B5);
if(user1==9)
output_low(Pin_B3);
output_low(Pin_B4);
//Display Digit 3
if(user0==0)
output_low(Pin_A6);
output_low(Pin_A7);
output_low(Pin_A0);
output_low(Pin_A1);
if(user0==1)
output_high(Pin_A6);
output_low(Pin_A7);
output_low(Pin_A0);
output_low(Pin_A1);
if(user0==2)
output_low(Pin_A6);
output_high(Pin_A7);
output_low(Pin_A0);
output_low(Pin_A1);
if(user0==3)
output_low(Pin_A0);
output_low(Pin_A1);
if(user0==4)
output_low(Pin_A6);
output_low(Pin_A7);
output_high(Pin_A0);
output_low(Pin_A1);
if(user0==5)
output_low(Pin_A7);
output_low(Pin_A1);
if(user0==6)
output_low(Pin_A6);
output_low(Pin_A1);
if(user0==7)
output_low(Pin_A1);
if(user0==8)
output_low(Pin_A6);
output_low(Pin_A7);
output_low(Pin_A0);
output_high(Pin_A1);
if(user0==9)
output_low(Pin_A7);
output_low(Pin_A0);
void comparetemp(int user2, int user1, int user0, int actual2, int actual1, int actual0)
do
output_high(Pin_B6);
//calculatetemp(actual2, actual1, actual0);
checkpushbutton(user2, user1, user0, check);
if(check==true)
setdigit1(actual2);
setdigit2(actual1);
setdigit3(actual0);
setdigit1(user2);
setdigit2(user1);
setdigit3(user0);
}while((actual2==user2 && actual1==user1 && actual0<user0) || (actual2==user2 && actual1<user1 && actual0==user0) ||(actual2<user2 && actual1==user1 && actual0==user0));
output_low(Pin_B6);
asmallri
PostPosted: Fri Apr 14, 2006 12:52 am     Reply with quote
Its too hard to read your code. Edit your message and to include [c0de] (use o not 0) at the start of your code and [/c0de] (use o not ).
Also you code is far too long. Chop it down and post the smallest code segment that demonstrates your problem.
Regards, Andrew
