Exit from long loop with interrupt?
TekTrixter
PostPosted: Mon Apr 10, 2006 5:40 pm     Reply with quote
Currently the program starts / stops the blinking pattern of the LEDs attached to the output pins. However, as written it can't stop within the loop, only between loops. How can I cause the loop to end after the interrupt? I know that I could set a flag in the interrupt and then check it between LED changes, but that doesn't seem to be an elegant method.
#include "D:\Data files\robot\BlinkLED\BlinkLED.h"
void setup();
boolean btnToggle = false;
#int_EXT
void EXT_isr() {
   output_low(PIN_A2);   // indicate that program is within ISR
   disable_interrupts(GLOBAL);
   if (btnToggle){
      btnToggle = false;
   }else{
      btnToggle = true;
   delay_ms(50);
   clear_interrupt(INT_EXT);
   output_high(PIN_A2);
   setup();
   while(true){
      if(btnToggle){                         //change LED pattern
         output_toggle(PIN_B3);
         output_toggle(PIN_B2);
         output_toggle(PIN_B1);
         output_toggle(PIN_B5);
void setup(){
   setup_timer_1(T1_DISABLED);
   setup_vref(VREF_LOW|-2);
   ext_int_edge(H_TO_L);
   enable_interrupts(INT_EXT);
   setup_oscillator(OSC_4MHZ);
   output_float(PIN_B0);
   output_high(PIN_B3);
   output_high(PIN_B2);
   output_high(PIN_B1);
   output_high(PIN_B5);
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Mon Apr 10, 2006 8:00 pm     Reply with quote
Add more places where you test the flag, which you set in the ISR. For example:
while(true){
      if(btnToggle) goto endloop;                         //change LED pattern
// or you can also split up your delay routines like this
// instead of delay_ms(500);
for (i = 0; i < 5; ++i)
endloop:
asmallri
Re: Exit from long loop with interrupt?
PostPosted: Mon Apr 10, 2006 11:03 pm     Reply with quote
Using a flag is in the interrupt handler is elegant. I suggest the following:
    get rid of the disable interrupts in the interrupt handler unless there are other interrupt sources that you specifically want disabled.
    get rid of the enable_interrupts(global) in your interrupt handler - it is a sure way to crash the PIC.
    get rid of the clear_interrupt(INT_EXT) from the interrupt handler . It is not required the compiler does it automatically for you.
    get rid of the delay_ms from the interrupt handler. By putting this in the handler the compiler will add a disable interrupts into the mainline code whenever delay_ms is invoked which means you may lose interrupts.
    A method I use is to enable a timer in the interrupt handler - in your case one with 50ms timeout. You can then sit in the handler until the timeout expires - alternatively (the method I use) you can return immediately from the handler and in the mainline you can test if the timer is running (means an interrupt has occured and you are waiting for a timeout) then loop until the timer IF is set. You can then stop the timer, clear the flag and clear the output.
    Alternatively (or in addition) use a timer instead of delay_ms() in the mainline. In this case you would clear the TF flag and start the timer. You you then sit in a while loop such as
         Ext_Intr_Processed_by_handler = false;
         while (!Some_Timer_TF & !Ext_Intr_Processed_by_handler)
                  // do nothing
           // here if the timer expired or an interrupt was processed
           // do something else ....
Regards, Andrew
Humberto
PostPosted: Tue Apr 11, 2006 7:33 am     Reply with quote
#INT_EXT
void EXT_isr()
   if( btnToggle)
     { btnToggle = false; }
     { btnToggle = true;  }
void my_wait_loop(int times)
   do
      delay_ms(10);
     }while((--times) && (btnToggle));
In main replace delay_ms(500) for my_wait_loop(n);
         my_wait_loop(50);
         my_wait_loop(50);
Humberto
Mark
PostPosted: Tue Apr 11, 2006 8:58 am     Reply with quote
Just to add upon what's already been posted
   do
      delay_ms(10);
  int state;
  setup();
  while(true)
    state = 0;
    while (btnToggle)
      switch (state)
        case 0:
        case 1:
        case 3:
        case 4:
        case 5:
        case 6:
          state = 0;
          continue;
      state++
      my_wait_loop(50);
TekTrixter
PostPosted: Wed Apr 19, 2006 10:26 am     Reply with quote
Thank you to everyone that replied. Mark's suggestion of a CASE is what I was origionally looking for (it avoids cut and pasting code). I also needed the interruptable delay as well (and didn't even know it!). I'd like to specificly thank asmallri for the list of corrections and hints.
I'm now working on a function for an interruptable delay using a timer interrupt and a break_delay flag.
Again, thank you to everyone that helped out.
