mmprestine
Joined: 13 Jan 2004 Posts: 29 Location: Green Bay, Wisconsin
| 12F683 analog |
Posted: Fri Apr 07, 2006 8:56 am |
compiler version: 3.242
I have been working on a project that uses the sAN0 and sAN3 analog inputs on the 12F683 and seem to have found serveral discrepencies between the compiled code and the datasheet. Sample code below:
#include <12F683.h>
#device *=8 adc=10
#use delay(clock=8000000)
#use rs232(baud=4800,xmit=PIN_A1,rcv=PIN_A2,parity=N,bits=8,errors)
//#priority EXT,TIMER0
#ZERO_RAM
setup_oscillator(OSC_8MHZ);
// initialize adc hardware
setup_adc_ports(sAN3|VSS_VDD);
set_adc_channel(sAN3);
while (TRUE){
printf( "Analog Data:%Lu\n\r", read_adc() );
this results in this ASM:
.................... // initialize adc hardware
.................... setup_adc_ports(sAN3|VSS_VDD);
03F9: BCF 1F.6
03FA: BSF 03.5
03FB: BCF 1F.0
03FC: BCF 1F.1
03FD: BCF 1F.2
03FE: BSF 1F.3
.................... setup_adc(ADC_CLOCK_INTERNAL);
03FF: BSF 1F.4
0400: BSF 1F.5
0401: BCF 1F.6
0402: BCF 03.5
0403: BSF 1F.7
0404: BSF 1F.0
In the data sheet to setup for sAN3 the control register 1F.2 and 1F.3 should be set. And the select regiester should be 9F and not 1F.
I am I correct about this?
Has any one used the analog on this chip and if so what compiler version?
Regards,
Matt |
Humberto
Posted: Fri Apr 07, 2006 12:20 pm |
Well, this is an old subject and reason why I even see is between us.
It is an error in the constant definition in the 12F683.h file.
In the paragraph:
// Constants used in SETUP_ADC_PORTS()
Replace this lines
#define sAN0 1 //| GP0
#define sAN1 2 //| GP1
#define sAN2 4 //| GP2
#define sAN3 8 //| GP4
For this:
#define sAN0 0 //| GP0
#define sAN1 4 //| GP1
#define sAN2 8 //| GP2
#define sAN3 12 //| GP4
and the life will smile you.
Humberto |
Posted: Fri Apr 07, 2006 12:31 pm |
Here is an explanation of the listing file:
00D6: BCF 03.5 // Bank 0
00D7: BCF 1F.6 // VCFG = 0
00D8: BSF 03.5 // Bank 1
00D9: BCF 1F.0 // AN0 = digital pin
00DA: BCF 1F.1 // AN1 = digital pin
00DB: BCF 1F.2 // AN2 = digital pin
00DC: BSF 1F.3 // AN3 = Analog pin
00DD: BSF 1F.4 // ADCS = 011 = use internal clock
00DE: BSF 1F.5
00DF: BCF 1F.6
00E0: BCF 03.5 // Bank 0
00E1: BSF 1F.7 // ADFM = 1 (right justify)
00E2: BSF 1F.0 // ADON = 1
Also, the parameter you have used in the following line is not valid:
| Quote: | | set_adc_channel(sAN3); |
You must use numbers for the channels. It should be:
| Code: | | set_adc_channel(3); |
This is in the manual. |
mmprestine
Posted: Fri Apr 07, 2006 1:24 pm |
Thanks,
I will change it and give it a try. Strange that it compiles with the wrong parameter.
Matt |
mmprestine
Posted: Fri Apr 07, 2006 1:51 pm |
| Well as soon as I change the header file to Humberto's new defines and try to use analog 3 the serial does not function anymore. By serial I mean that I am using the external interrupt to parse serial data through a Max232. It appears to be affecting the external interrupt. Any thoughts on this? |
Posted: Fri Apr 07, 2006 2:01 pm |
Put the #define statements back to the way they were in
the original 12F683.H file. Example:
#define sAN3 8 //| GP4 |
Then do your A/D setup code like this:
| Code: | setup_adc_ports(sAN3 | VSS_VDD);
Humberto
Posted: Fri Apr 07, 2006 2:28 pm |
| Quote: |
PCM Programmer you are right, sorry. It was an old issue.
Humberto |
