ANGLE CALCULATION
horizontech
ANGLE CALCULATION
PostPosted: Wed Jul 09, 2003 8:21 pm     Reply with quote
HI!
I try to get Angle from ADXL105 is analog output,
is very instable ..... i have connected to PIC16f876 in A0
analog input pin.. in 8 bit is not get wide range between 0 to 90 tilt.
in 16bit is moving right but is not stable ???
My question is what is the best way or sensor to get the right
tilt angle, i need .5 degre bettwen step
thank for your help
Alain Tanguay
___________________________
Original Post ID: 144515830
Kenny
Re: ANGLE CALCULATION
PostPosted: Wed Jul 09, 2003 11:21 pm     Reply with quote
<font face="Courier New" size=-1>:=HI!
:=I try to get Angle from ADXL105 is analog output,
:=is very instable ..... i have connected to PIC16f876 in A0
:=analog input pin.. in 8 bit is not get wide range between 0 to 90 tilt.
:=in 16bit is moving right but is not stable ???
:=My question is what is the best way or sensor to get the right
:=tilt angle, i need .5 degre bettwen step
:=thank for your help
:=Alain Tanguay
I dont think it will be possible to get the performance you need, especially for high tilt angles.
In any case the signal must be amplified and filtered first using op-amps before going into the A/D of the PIC. Scaling should be 1g for full scale of the A/D and 10 bit sampling.
Most of the noise is high frequency so filtering to around 1Hz will give much better performance.
Regards
Kenny
</font>
Original Post ID: 144515832
Bill Turnip
PostPosted: Thu Jul 10, 2003 8:05 am     Reply with quote
Alain -
Even with an 8- or 10-bit ADC you can do OK, that's not the problem.
You will not get enough sensitivity at high angles with a single axis sensor. The output of the sesnor is proportional to Sin(angle), the sensitivity then goes as Cos(theta), which heads towards 0 as you approach +/- 90 degrees. Single axis devices are usually used when the angle is confined to +/- 60 degrees from the horizontal.
Good luck,
Bill
:=HI!
:=Alain Tanguay
Original Post ID: 144515845
Neutone
PostPosted: Thu Jul 10, 2003 3:40 pm     Reply with quote
:=HI!
:=Alain Tanguay
Use a input filter. An RC circuit will work or you can oversample and use a digital filter. Here is one that I like because it aproximates an RC circuit.
Filtered_input=Filtered_input-(Filtered_input/8)+(Raw_input/8)
This works very good for a noisy input. This method requires about 16 samples to become stable.
Original Post ID: 144515859
