can't get ICD demo to work
Thomas Umble
PostPosted: Wed Jul 09, 2003 5:36 pm     Reply with quote
Can't understand why this will not compile. Any help would be appreciated. This is out of the Development Kit Exercise Book section 4 (EX4A.c)
tom
#include <16f877.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT,PUT
#use delay (clock=20000000)
#define GREEN_LED PIN_A5
#define YELLOW_LED PIN_B4
#define RED_LED PIN_B5
#define PUSH_BUTTON PIN_A4
typedef enum colors {GREEN, YELLOW, RED} ;
light_one_led(colors) {
output_high (GREEN_LED);
output_high (YELLOW_LED);
output_high (RED_LED);
switch (colors) {
case GREEN : output_low(GREEN_LED); break;
case YELLOW : output_low (YELLOW_LED); break;
case RED : output_low (RED_LED); break;
wait_for_one_press() {
while(input (PUSH_BUTTON));
while(!input(PUSH_BUTTON));
main(){
while (true){
light_one_led (GREEN);
wait_for_one_press ();
light_one_led (YELLOW);
light_one_led (RED);
___________________________
Original Post ID: 144515827
Bill Turnip
Re: can't get ICD demo to work
PostPosted: Wed Jul 09, 2003 6:31 pm     Reply with quote
Tom -
I don't have the book or kit you refer to, but exactly what error message do you get? Also, is the value of "true" defined somewhere?
Bill
:=Can't understand why this will not compile. Any help would be appreciated. This is out of the Development Kit Exercise Book section 4 (EX4A.c)
:=tom
:=#include <16f877.h>
:=#device ICD=TRUE
:=#fuses HS,NOLVP,NOWDT,PUT
:=#use delay (clock=20000000)
:=#define GREEN_LED PIN_A5
:=#define YELLOW_LED PIN_B4
:=#define RED_LED PIN_B5
:=#define PUSH_BUTTON PIN_A4
:=typedef enum colors {GREEN, YELLOW, RED} ;
:=light_one_led(colors) {
:= output_high (GREEN_LED);
:= output_high (YELLOW_LED);
:= output_high (RED_LED);
:= switch (colors) {
:= case GREEN : output_low(GREEN_LED); break;
:= case YELLOW : output_low (YELLOW_LED); break;
:= case RED : output_low (RED_LED); break;
:=wait_for_one_press() {
:= while(input (PUSH_BUTTON));
:= delay_ms(100);
:= while(!input(PUSH_BUTTON));
:=main(){
:= while (true){
:= light_one_led (GREEN);
:= wait_for_one_press ();
:= light_one_led (YELLOW);
:= light_one_led (RED);
Original Post ID: 144515828
PostPosted: Wed Jul 09, 2003 7:34 pm     Reply with quote
:=tom
:=#device ICD=TRUE
Change the line below to this:
typedef enum {GREEN, YELLOW, RED} colors;
light_one_led(colors value) {
Change the next line to this:
switch (value) {
:= delay_ms(100);
:=main(){
:= while (true){
Original Post ID: 144515829
Thomas Umble
PostPosted: Thu Jul 10, 2003 2:11 pm     Reply with quote
Thankyou very much. IT WORKS! I don't understand it, but it works.
Tom
:=:=Can't understand why this will not compile. Any help would be appreciated. This is out of the Development Kit Exercise Book section 4 (EX4A.c)
:=:=tom
:=:=#include <16f877.h>
:=:=#device ICD=TRUE
:=:=#fuses HS,NOLVP,NOWDT,PUT
:=:=#use delay (clock=20000000)
:=:=#define GREEN_LED PIN_A5
:=:=#define YELLOW_LED PIN_B4
:=:=#define RED_LED PIN_B5
:=:=#define PUSH_BUTTON PIN_A4
:=Change the line below to this:
:= typedef enum {GREEN, YELLOW, RED} colors;
:=:=typedef enum colors {GREEN, YELLOW, RED} ;
:= light_one_led(colors value) {
:=:=light_one_led(colors) {
:=:= output_high (GREEN_LED);
:=:= output_high (YELLOW_LED);
:=:= output_high (RED_LED);
:=Change the next line to this:
:= switch (value) {
:=:= switch (colors) {
:=:= case GREEN : output_low(GREEN_LED); break;
:=:= case YELLOW : output_low (YELLOW_LED); break;
:=:= case RED : output_low (RED_LED); break;
:=:=wait_for_one_press() {
:=:= while(input (PUSH_BUTTON));
:=:= delay_ms(100);
:=:= while(!input(PUSH_BUTTON));
:=:=main(){
:=:= while (true){
:=:= light_one_led (GREEN);
:=:= wait_for_one_press ();
:=:= light_one_led (YELLOW);
:=:= light_one_led (RED);
Original Post ID: 144515857
